C4 VTS high rpm causes ems fault.
Results 1 to 3 of 3
  • 1 Post By Ken W
Thread: C4 VTS high rpm causes ems fault.
    Member redsky's Avatar
    Northern Vic
    31
    Default C4 VTS high rpm causes ems fault.
    After a five year break since the C5, i’m A Citroen owner once more with a C4 VTS i’ve been happily bonding with over the last few months.
    An unusual problem over Easter though, a spirited drive through the mountains at high rpm sets of warning buzzers, lights and fault codes.
    after about 60 sec around 5-6000 rpm the engine warning light, buzzer, service light, Engine Management System Faulty and Speed Control System Faulty codes all activate. As soon as I backed off the engine warning light went off, but all others remain. Enegine performance seemed unchanged but I took it easy driving home.
    Criuse control came back online 2 days later and service and EMS fault dissappeared the day after that.
    Another more modest but still enthusiastic drive tonight caused the problem to resurface again.
    Car is a low km (66k) ‘05 with recent service and timing belt change. Haven’t done air and fuel filters though.
    has anyone come across this issue before?
    cheers.
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,928
    Sounds like it was severe enough to have recorded a few fault records. You need to find someone who can read the fault codes for you and that will give you a lead on where the problem is.
    Cheers, Ken
    Greg likes this.
    Jul 2013
    Newcastle/ central coast
    1,946
    With the cam belt if you can chase up who did it they are very exact on cam timing they have two possible pin locations I have seen this experience before and found timing out
