DS Rubbers Advice
  • 1 Post By GreenBlood
Thread: DS Rubbers Advice
    Fellow Frogger! Inspector Clouseau's Avatar
    Dec 2002
    North Coast NSW
    188
    Default DS Rubbers Advice
    I've bought some rubbers for the DS Safari and managed to replace the door window seals and a couple of others. However, I can't work out how to remove and replace the white rubbers that seal against the bottom of the doors. Any suggestions?
    Also, can any one recommend a product for sealing between the sill and the body. There is a bead of some old sealant that is breaking down. The car is basically rust free and I'd like to keep it that way.
    Martin
    8,184
    Quote Originally Posted by Inspector Clouseau View Post
    Martin
    Hi Martin,
    The fixings for the stainless holder for that rubber are hiding under the trim, carefully lever the trim out and all will be revealed. . .
    Vincenzo likes this.
    08 C5 X7 HDi very Noir
    Dec 2002
    North Coast NSW
    188
    Awesome. Thanks Chris
    Sent from my E5823 using aussiefrogs mobile app
    9,774
    Posidriv screw heads too - PZ0, PZ1 and PZ2 mostly and lots of them on a later D. Philips screwdriver bits will round out the heads, so don't use them when you see a Posidriv screw.
    Dec 2002
    North Coast NSW
    188
    OK. Will do, David. Cheers
