Citroen CX starting issues
Like Tree5Likes
  • 1 Post By Hotrodelectric
  • 2 Post By UFO
  • 2 Post By gerrypro
Thread: Citroen CX starting issues
    Sep 2013
    nz
    69
    Default Citroen CX starting issues
    Morning all,
    My venerable 1977 CX 2400 Pallas has been playing up since sitting for a few months. I got it going rather promptly with a jump and some fresh fuel and it ran well.
    However on subsequent occasions (and for no reason i can decipher) when I go to start it, it will simply not turnover. I.e. it doesn't even sound like the starter is trying. There i plenty of juice in the battery.
    On other occasions it simply starts immediately.
    When it does not start, and I strain my hearing I can hear a click in the engine bay when I turn the ignition to start. This suggests to me that a relay or similar is playing up. Or could be the starter failing, but the starter is not making an noises when trying to start.
    Given the inherent birds nest around the relays, I would be grateful for some pointers and or advice in trying to source the problem.
    Thanks in advance!
    San Diego, California, USA
    3,534
    I would investigate your battery cables- both of them. Clean and tight. Make sure the cables aren't corroded. From there, check out the starter solenoid. It may be sticking. It's also possible that the starter itself is due for a rebuild. Any competent sparky can do a starter drain test.
    UFO likes this.
    CitroŽn Tragic UFO's Avatar
    9,719
    I suggest planning ahead for the next time it DOES start. Get it to full height while it's running and whack some stands in the right places to support the front of the car in the air - or even better if you have it - get it on a hoist. You have to get under the front of a CX to remove and replace the starter.
    Hotrodelectric and JohnW like this.
    3,534
    I'll second that. A flat hydraulic Citroen is diabolically difficult to work on.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,067
    Those low profile racing trolley jacks are worth their weight in gold when working on a CX .
    Hotrodelectric and UFO like this.
    Cheers Gerry
