CX 2400 Clutch Change
Results 1 to 8 of 8
Like Tree3Likes
  • 2 Post By DoubleChevron
  • 1 Post By Jinandfonic
Thread: CX 2400 Clutch Change
    266
    Default CX 2400 Clutch Change
    Hi
    Can anyone tell me what work is involved with changing the clutch on a CX2400 5 spd manaul?
    Does the engine have to come out?
    How expensive is the clutch kit?
    Regards
    Alan
    16,426
    Have a look on Ebay uk and see what sort of price the clutch kits are at the moment. also budget for a camshaft seal and check the camshaft carrier bearing, the driveshaft inner bearing and spigot while you are there.
    Its a reasonable sized job, driveshafts out, engine & gearbox out through the top and split on the floor outside of the car.
    seeya
    266
    Default Big Job
    Shane
    So it can't be done with the engine in the car?
    So if it goes to a mechanic it will cost thousands?
    Regards
    alan
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,928
    No it can't be done in the car because the camshaft pokes through the bell housing on the gearbox by a long way and there is not enough room in the engine bay to get the gearbox off enough to clear the camshaft.
    Cheers, Ken
    16,426
    Its not a difficult job ... I"d suggest DIY if its a hobby car. If its your daily driver. Yes I imagine it will be expensive as there is quite a bit of time involved in extracting the motor and putting it back!
    The cost however probably will not be the issue .... it'll be finding a mechanics willing to take it on!
    seeya
    UFO and JohnW like this.
    266
    Thanks guys
    Any way of telling how good the clutch in a car is?
    How many kiolmetres will a car general run on one clutch?
    16,426
    Quote Originally Posted by 120L View Post
    Thanks guys
    Unless its a petrol turbo, CX's are not hard on clutches. If it works ok, doesn't slip or shudder etc... It would be one of the last things I'd be concerned about
    Feb 2013
    451
    Hi
    Regards
    Alan
    I had DS motors do the clutch on my Cx2200 before they closed, very Lucky. I ordered the clutch from CXBasis, delivered within a fortnight. All up it was no dearer than any other car I've had done. Did the main seals on the engine, engine mounts plus anything else the John suggested and here by the brains trust😉 It still looks like a bomb yet it drives so well! I've since found my local servo mechanics workshop here in North Brisbane is owned by a South African & said he worked on so many over the years back there. Phew, as I don't have a hoist or engine crane, I now have some where to go I can walk home from if a big problem arises.
    JohnW likes this.
