C4 - control arm bushes
Results 1 to 10 of 10
  • 1 Post By dmccurtayne
Thread: C4 - control arm bushes
    CitroŽn Tragic UFO's Avatar
    9,721
    Default C4 - control arm bushes
    I've been chasing a problem with the C4 in that there is a "clunking" in the front end at various times and a bit of wheel wobble. I'm expect that it is the front control arm bushes have worn (137,000km) and I have researched to find that replacement bushes (2 for each arm) are available. Also available are entire replacement arms with bushes. The price of each arm is more than double the price of the bushes for each arm.
    I have an hydraulic press available to push out the old and push in the new bushes.
    The question is - which would you do. Complete new arms or just the bushes?
    Jul 2013
    Newcastle/ central coast
    1,936
    Check the tie rods not ends pretty common on c4 and 307
    9,721
    OK, I'll have a look this weekend.
    16,421
    I have just found the answer to your problems
    F/SALE Citroen CX 25 Pallas IE. Auto 1984
    Go For it !!!!
    9,721
    Quote Originally Posted by dmccurtayne View Post
    Thanks - but I am a little confused. Did you mean:
    Check the tie rod ENDS. ?
    Jul 2013
    1,936
    No tie rods they screw into the rack and the ends
    https://rover.ebay.com/rover/0/0/0?m...2F262732049896
    9,721
    OK - I was not aware (ignorant) that the tie rod had a ball joint on the inner end. Thanks.
    Jul 2013
    1,936
    Donít worry most mechanics donít
    UFO likes this.
    9,721
    Don’t worry most mechanics don’t
    Thanks - needed a chuckle.
    Jul 2013
    1,936
    Do you have a wobble in your rod
