Seek advise on ID21F + VIDEO for share!
Results 1 to 25 of 36
Like Tree4Likes
Thread: Seek advise on ID21F + VIDEO for share!
    Tadpole kelvinmingxd's Avatar
    May 2017
    Hong Kong
    15
    Default Seek advise on ID21F + VIDEO sharing
    Dear all,
    Thank you for all your replies on the last topic, I gave up on that idea due to complicity and apparently no one in Hong Kong can deal with that!
    I encounter some more important issues now, I have to fix these issues to get it on road legally in Hong Kong!
    1. May I ask if there are official anchor points for rear seat belts in the 1967 ID21F? As the government needs supporting documents to prove that the seat belt is effective so that it can carry 4 people leagally
    The current seat belts are mounted here as showed.
    2.I would like to fit a reverse light to the car, is it possible to combine the lights and brake lights into one light bulb and free up space for reverse lights? Like they did in later models? If not, what aftermarket solution looks the best on the safari? Any recommendation?
    Left: Current taillight without reverse light Right: Later model with reverse lights
ID:	104419Click image for larger version.
    3.I want to change the interior mirror to a correct one, but the mounting point on the dashboard seems to be broken, I want to know if a dash-mounted mirror can still be installed?
    Left: Mounting point current condition Right: The mirror I would like to fit
ID:	104421Click image for larger version.
    4. The speedometer shows only miles/hr now, HK government requires a km/h speedometer, I want to know where can i find one for my RHD ID21F? Or if any of you have spare parts for sale?
    The dash I have now
    I am looking forward to your advice and I hope to get it on road as soon as possible! Thank you so much!
    Best regards,
    Kelvin
    I would like to share this video I filmed, hope you enjoy it!
    https://youtu.be/eblk9hikeMs
    Vincenzo likes this.
    Apr 2016
    Bedford, UK
    705
    Hi Kelvin. greetings from the UK. I can't see your photos, but the video is great!
    Attached here is a diagram that shows the seatbelt mounting points in a Berline - not a Safari. Not sure it's going to answer your question but it might give you some ideas. Note that the eyelets have reinforcing plates to add extra support to them.
    San Diego, California, USA
    3,534
    I can take a shot at this one:
    Yes, it is possible, but why? Depending on what you have, not only will you need to change out the globe socket (1157 to an 1156) but the wiring will be a pain in the rump, and the performance won't be at all that good. You'll be better off installing a dedicated lamp under the bumper. Common on upper spec later Ds. Being a '74, does your transmission have the reversing switch in the nose cone? If not, wiring up a dash switch (in this case, preferably one with an 'on' indicator) is fairly simple.
    3,534
    Alrighty- I opened my mouth before knowing all of your plight. I went and looked at your video (very nice) and saw you have a Safari. I was assuming sedan. This puts your changeout question in a different light. So! Yes, you can do as you propose , dependent on three things: 1) of course, Hong Kong says it's OK 2) you still have brake and tail lights when this is all over and 3) you can source clear or white lenses. I still think a dedicated lamp would be the better, easier way to go. But the answer is yes, it can be done, since you have spaces enough in the light clusters. Just be aware that you will still need to change the socket from dual to single contact, and the rear fender wiring will need a second pair of hands to help with the fender.
    May 2017
    Hong Kong
    15
    Thank you so much, I have this diagram too, but the HK government need a diagram of Safari. I do know that some later model in some countries have fitted with the rear 3-point seatbelts, but need to find out an official document about it. Also, I am trying to find pictures of safari with rear seat belt.
    May 2017
    Hong Kong
    15
    Thank you, this is very useful!
    Apr 2016
    Bedford, UK
    705
    Mirror: Yes. You should be able to take off the broken base plate and put a pallas mirror there if you want to. But you will need to get inside the dash to remove the nut holding the broken base plate. i think you may be able to do this by removing the Map pocket/ radio and sticking your arm inside? if not, the other way in would be to take out the panel that holds the instrument cluster.
    May 2017
    Hong Kong
    15
    Thank you! I will have to change the cluster as well, so they can be done at the same time
    May 2017
    Hong Kong
    15
    do I need another base plate to install a Pallas mirror or the mirror comes with a new base?
    8,184
    Icon3
    Quote Originally Posted by kelvinmingxd View Post
    Dear all,
    The dash I have now
    Best regards,
    Kelvin
    A bit rugged but you may be able to swap speedo into your beezle
    For sale km/h CITROEN DS 21 PALLAS 67
    08 C5 X7 HDi very Noir
    May 2017
    Hong Kong
    15
    Thanks, but it seems to be sold already
    8,184
    Icon11
    oops, sorry I didn't notice it had found a home - we'll keep looking
    May 2017
    Hong Kong
    15
    Also, I want to know that if I should put the suspension into its lowest setting before turning off the car if the car won't be used for a long time (e.g. half month), or should I just leave it in the normal ride hide and let it drop naturally?
    3,534
    You can do either, but leaving the car in normal won't hurt a thing.
    Mar 2017
    Grafton
    130
    What a beautiful car and thanks for the video. Regarding the reverse lights. As you may not have the fittings for the reverse light switch at the gearbox, a simple reliable solution is to mount a generic long arm micro switch under a convenient bolt on the gearbox housing and use a battery clamp or simular on the selector shaft to close the switch when reverse is engaged.
    Sent from my LG-K520 using aussiefrogs mobile app
    3,534
    I like the idea of a microswitch. I'd probably go the anal route and try for some sort of weather shield. And I would recommend a 10A fuse and a relay to shut the lamp off automatically if, by some chance you leave the car in reverse while parked.
    May 2017
    Hong Kong
    15
    Encounter another problem now!
    As there is no hazard light fitted, I have to fit it by myself.I read some article on the internet, and I'm still quite confused on what should I buy to make it work, can anyone help me on this?
    Apr 2016
    Bedford, UK
    705
    Not done it myself but you should be able to get plenty of advice here. There is also an official Citroen technical update sheet that tells you how to wire-in hazzards to a DS
    Fellow Frogger! Vincenzo's Avatar
    Aug 2014
    Auckland, NZ
    161
    Does the Hong Kong government not make any allowance at all for classic cars under the law? Or is this a case of an overly bureaucratic official needing a donation?
    DS23 Pallas BVM Vert Argente - in ground up restoration, soon to be BVH.
    DSpecial 4speed Beige Vanneau, previous ; XM 2.0, maroon, my first.
    And a variety of the usual crapboxes before seeing the light. Except my Mini Cooper with the 3.4 cam and twin webers - that wasn't a POS.
    Bikes -
    Ducati GTS860, CB350, XT550, Z500, T250, XR200, ag90.
    Fellow Frogger! robo's Avatar
    147
    Speedo converter? Seek advise on ID21F + VIDEO for share!-60fb5449-8797-40e4-8043-3026e70c59d0.jpg
    Apr 2016
    Bedford, UK
    705
    Still no response to your question about how to fit hazard lights? While you're waiting for the good advice to roll in, have a look here:
    DS Hazard switch and temperature gauge etc
    Hotrodelectric likes this.
    3,534
    Sorry I didn't reply yesterday. I was busy having eye surgery.
    It's a pretty easy thing to install on a D. If you need help, PM me. Budge's instructions fairly well cover it.
    3,534
    Quote Originally Posted by robo View Post
    Speedo converter? Click image for larger version.
    Do you have a link for that? I want to have a look at the other pics before I actually say something. The one clear pic looks like a speed generator for an early electronic speedo.
    Apr 2016
    Bedford, UK
    705
    Kelvin's car has the older dash and so the older stalks. Different functions and different wiring connections. I couldn't find a hazard light wiring diagram for the mid period dash.
