New RHD Octopus ( return hoses ) for Xantia
Results 1 to 10 of 10
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,157
    Default New RHD Octopus ( return hoses ) for Xantia. Be Quick!
    Ive managed to find some new old stock of these in the UK
    There about $360 plus freight.
    I have one on order which is coming from Germany through my UK guy.
    If anyone wants one speak up quick and Ill see how many there are
    I can have them sent together and happy to distribute within Australia once they land.
    Cam
    Armidale
    1,821
    Cam do you know whether these are specific to particular Xantiae - ie Series 1 vs Series II and 16v vs Turbo CT (not to mention V6s, Diesels etc.)?
    If they fit a Series II Activa then I'm in!!
    Alec
    Nov 2003
    Bondi
    3,157
    I assume they are for HA2 system. Yours 'may' be the same.
    Ive had word its the last one he has so I propose making a copy if it with either hose and joiners or like this
    Xantia Octopus - Billet Replacement Post number #5.
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    7,642
    It depends what the octopus includes. This is one that someone bought new (John W?) and took a photo of. Using that and having help from Addo who showed me how to 'skin' the multiple connector by cutting off all the rubber and getting the nylon tree to attach new rubber tubing to. I expect this is the "right hand" octopus, because the only difference between left and right handed octopus is the longer tube for the steering rack return. If the French were half bright (we did have to help them out in two World Wars), they would have connected a metal return pipe running the whole length of the RHD steering rack to end exactly where the French rubber return hose connected to the LHD steering rack. That way all the rubber return lines would be identical.
    The problem I have is all the little return lines from the front suspension that disappear behind the LHM tank. They have right angle bends and nylon T junctions. They are difficult to get to both from beneath when on a hoist or bending over with the LHM tank removed. It is difficult to get LHM friendly rubber to replace a lot of this and the French chose obscure sizes that have no imperial equivalents. Fortunately the LHM leaks can be ignored whilst I have a ready supply of LHM.
    John
    9,721
Name:	Xantia Octopus Main txt.jpg
    John
    Yes, that's my photo. I think I posted all three of them here 2-3 years ago. All with dimensions.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    Peugeot 306 XT 1995 (daughter's)
    Citroën CX Pallas 1980
    17,440
    If your silver soldering skill (brazing in truth) is up to the task.
    I'd start with a piece of 16 or 20mm mm SHS (square hollow section) tube and the correct fittings.
    And drill the tube appropriately and solder in the fittings.
    I'd estimate the manufacture time at less than 2 hours and the all up cost less that $50.
    Even after a number years I see the billet concept as extravagant and having no practical benefit, over the much cheaper fabricated option.
    And there is not even bragging rights, because the device is unseen once installed.
    Mutual Respect is Contagious
    7,994
    That is the approach taken here. . .
    Xantia Citro&eumln
    08 C5 X7 HDi very Noir
    8,744
    Brazed or soldered tube is the sensible solution for the long-term.
    NOS parts have the advantage of looking right and fitting straight in though. For the Xantia, there are many, many variations when you look at the parts lists.
    JBN
    JBN is offline
    7,642
    If you look at the third photo, the "tree" when skinned is just nylon. I just used the nylon tree and connected new rubber hoses. Simple. The nylon tree is very unlikely to deteriorate. I think replicating it in brass is overkill.
    If you were designing a Xantia from scratch, you would have a manifold fixed to top of the engine bay firewall, with all the various hoses of differing diameters joining it. Then, from that manifold, you would have one large diameter hose going to the LHM reservoir with no right angled bends, just a natural curve. That is the hose that would require replacing most because it would be the only hose disturbed when cleaning the filters and replacing the LHM. The way Citroen did it was to put stress on all return hoses when changing the LHM, hence the problem. Rubber doesn't last forever in a hot engine bay environment where it becomes brittle, but it still does its job UNLESS the brittle hose is moved or bent.
    In the days when Michelin owned Citroen, they had a vested interest in replacing rubber.
    New RHD Octopus ( return hoses ) for Xantia-jbn-008.jpgNew RHD Octopus ( return hoses ) for Xantia-jbn-010.jpg
    John
    Nov 2003
    Bondi
    3,157
    Yes it can be done many ways.
    Ive the new set of hoses coming in a couple of weeks. Hoping to sort the issues out!
