DS wheel balancing
Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By Glenn Drake
  • 1 Post By Leeroy69
Thread: DS wheel balancing
    Fellow Frogger! lamoor's Avatar
    sydney-newport
    369
    Default DS wheel balancing
    could some person please advise me if it possible to balance the wheels on a DS by having the weights on the inside ?
    what is the usual ??
    Apr 2014
    Phoenix, Arizona USA
    681
    Weights are ordinarily placed both on the inside and the outside to cancel out any lateral imbalance
    John T.
    San Diego, California, USA
    3,535
    Quote Originally Posted by lamoor View Post
    Quote Originally Posted by citroenthusiast View Post
    Do you have access to an on-car wheel balancer? Have you made sure that the inside of the wheels are spotlessly clean?
    Originally from the factory the cars used no wheel weights. Michelin produced both the tire and the wheel as an assembly, and as such were able to carefully control the wheel balance. Even today, with "off-brand" tires, you can still get good result just so long as the wheel isn't damaged and the tire is a reputable brand.
    If you do need to balance a wheel, you can use one of the on-car balancers. Just mount your wheel to be worked on on the rear so it freely spins. Also, make sure there aren't glops of accumulated road gunk, grease, dirt, and so on. You'll be amazed at how that little bit can throw a wheel out of balance
    sydney-newport
    369
    Default Ds wheeel balancing
    many thanks gents will try to get this as i really prefer NO weights on the rims showing.
    Apr 2012
    Templestowe, Melbourne
    57
    Just did my DS 23 wheels this way at tyresplus in Ringwood.
    Shows off my new painted rims!
    Glenn
    Hotrodelectric likes this.
    Member Leeroy69's Avatar
    Sep 2017
    33
    I've probably noticed this a little too late to be of any use here, but I'll throw in my 2 bob anyway.
    Yes, wheels can be balanced without weights on the 'outside' lip. There are a couple of ways to do this, but the most common would be what is known as a static balance. Doesn't give quite as accurate a balance as a regular 'dynamic' balance, however, during my many years in the tyre industry I've rarely had any issues. Besides, the only times you're going to notice an unbalanced wheel is when travelling between roughly 90-120kph.
    Feb 2012
    Ongar / England
    840
    Hello, anyone on here used Dynabeads in their tyres to balance them?
    Dynabeads Tyre Balancers. The dynamic way to balance your tyres.
    Made in the USA
    3,535
    Quote Originally Posted by Leeroy69 View Post
    The only problem with that is most D wheels don't have the center hole for the hub like most any other car. Certainly not the center lock ('55-'65) wheels. I have seen centers cut out on the 5-lug wheels, but with that you lose the ability to lift the wheel up to the hub with the factory tire tools.
    Mar 2017
    Grafton
    136
    Yes I have used them for years!
    Seem to work very well.
    Easier to install when the tyre is fitted, but 1mm beads can be put in via the valve stem
    Sent from my LG-K520 using aussiefrogs mobile app
