mystery ID19 weber carb component
Results 1 to 16 of 16
Like Tree4Likes
  • 1 Post By 2bxornot2bx
  • 1 Post By Budge
  • 2 Post By 2bxornot2bx
Thread: mystery ID19 weber carb component
    canberra
    272
    Default mystery ID19 weber carb component
    Before I buy a swap out Solex for my weber can anyone tell me what is the part obviously missing on this weber..
    Its on an ID19B
    Its a single barrelled weber
    Attached Thumbnails Attached Thumbnails mystery ID19 weber carb component-dsweber.jpg
    Ici.
    2,405
    it migt help if you have the engine version available Ashley, the code on the plate under the hydraulic pump.
    canberra
    272
    Thanks forumnoreason but I think to anyone who may be in the know they may be able to assist sans make/model/year. Replies may be in the spirit of. The missing bit is most likely the ?????? removed for some markets down to emmisions rules. Not essential. So yeah thanks but probably looking for generic carb advice with a smidge of model reference
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    19,302
    Is this any help? If you open the links on the right exploded view of the carburetor will open. - Citroën DS/ID and XM Web-Site
    Every day is a good day
    Ici.
    2,405
    I was just thinking in terms of the manifold.
    canberra
    272
    Ah ha I get you.
    canberra
    272
    Quote Originally Posted by FIVEDOOR View Post
    Thanks Fivedoor. Was on that very site yesterday. Could not find a match. !!
    I'll have another look though
    FIVEDOOR likes this.
    8,103
    Quote Originally Posted by 2bxornot2bx View Post
    I think you'll find that if your car is a manual there is nothing missing. . . now if you have a BVH that's another story.
    08 C5 X7 HDi very Noir
    canberra
    272
    Spot on .thanks Chris..mines a basic manual ID/DSpecial. That has made my decision
    BTW how did that missing component contribute to a BVH?
    8,103
    We need a BVH expert to clarify but it would be a hydraulic link with the the brain for throttle control. . .
    Apr 2016
    Bedford, UK
    609
    I'm not the expert you're looking for but I think i can explain:
    The 'missing' component (not needed on a manual gear change car) is the "accelerated idling device". Basically (with a bvh) you have two idling speeds - two carb set up positions. With your foot on the brake button the engine speed drops to below the clutch engagement speed (remember - there is no clutch pedal). When you lift your foot off the brake button, the carb opens a slightly, raising the engine speed above the point at which the clutch bites and.....the car magically creeps forward! There are other systems at play here as well - clutch and gears - but thats the essence of it.
    GreenBlood likes this.
    canberra
    272
    Magic reply..Thanks Budge that's more expert than I am. Saved me an unnecessary swap out cost and bother ..
    canberra
    272
    Final thoughts on topic. How is this carb left unblanked ? Thinking there'd be unwanted air ingress without blanking plugs etc
    8,103
    Icon3
    It's good to go as it is. . .
    This is a BVH Weber I have but it too can be used on a manual car with the base screw wound in
    This pic shows the BVH setup
    Attached Thumbnails Attached Thumbnails mystery ID19 weber carb component-carb6.jpg
    9,294
    Same casting, but not every hole is drilled / machined depending on the original application.
    canberra
    272
    Thanks all for info. I noticed that my carb DOES have the screw blanked out. Great news. I'll now just do a basic tune up with confidence that all systems are as they should be !
    GreenBlood and forumnoreason like this.
