Any tips to stop D sucking dust?
Results 1 to 11 of 11
  • 1 Post By Greg
Thread: Any tips to stop D sucking dust?
    Sep 2012
    Somewhere near Mudgee, NSW
    329
    Default Any tips to stop D sucking dust?
    Hi All,
    With the current dry conditions and the RFS recently running 2 D6 dozers up our road (not floated), our road has turned to talcum. Any tips in stopping the dust sucking up thru the door seals particularly the rear ones. It's amazing to see the dust waft in at 20 kph!.
    Have some new seals, in transit, that go along the body at the bottom of the door. One has disintegrated, and have just noted that the right passenger one is missing.
    Steve
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,365
    Run the blowers to build up pressure in the cabin.
    Roger
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,079
    Yes! That way the blowers will drag in the dust through the front ducts and send it straight into your face as you drive.
    Cheers Gerry
    Apr 2013
    Essendon
    671
    Not necessarily so Gerry unless you driving through somebody else's dust.
    You don't see dust flowing over the front of your car, do you?
    10,876
    The old school way, for example with Land-Rovers and their 'excellent' seals, was to close all windows and open the front vent. With the R8 - shut windows and run the ventilator fan. The trick, as Roger said, is to have a higher pressure inside the car than outside.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    3,079
    Quote Originally Posted by JAJEA View Post
    I was referring to the degraded foam lining in the second and third nose cars. My wife complained of that stuff coming out of the vents every time I put the fans on!
    Cheers Gerry
    Apr 2014
    Phoenix, Arizona USA
    681
    A nylon stocking pulled over the hose where it goes into the firewall is a good way to stop that foam from entering the cabin.
    John T.
    Mar 2017
    Grafton
    136
    In essence, the way to keep dust out is to keep the windows fully up. The better the seals the less dust. With a good boot seal and door seals less dust will get in, but even with good seals dust will enter if windows are down even a little.
    Big problem in summer! my DS has aircon. so can be kept reasonably clean inside.
    Good luck. David
    Jun 2003
    Lauderdale, Tasmania
    2,887
    Drive underwater.
    3,079
    Quote Originally Posted by gerry freed View Post
    Drive underwater.
    and wash the car at the same time! Two birds killed with one stone!
    Cheers Gerry
    Fellow Frogger! Greg's Avatar
    MAITLAND NSW AUSTRALIA
    617
    Hi Guys
    As the new DS air ducting is readily available, and reasonably cheap, especially from DF, there is no excuse for anyone to have air duct with crumbling foam?
    best regards,
    Greg
    Lasya likes this.
    We Have:
    We Had:
