Advice wanted concerning my 2001 Citroen C5 diesel 2 ltr
Results 1 to 7 of 7
    Jan 2015
    South Bowenfels
    7
    Default Advice wanted concerning my 2001 Citroen C5 diesel 2 ltr
    Engine stalls, even at 110kph and Anti pollution fault and service light indicates. It is also hard to start but will start again a few minutes later. Any suggestions as to what the problem may be?
    8,103
    Quote Originally Posted by Buckle View Post
    When was the fuel filter last changed?
    08 C5 X7 HDi very Noir
    8,171
    110 kph = motorway. Is this a regeneration failing? (Both lights lit). How far had you travelled at speed?
    Is the cold start at Bowenfels a frosty winter or a summer thing?
    9,294
    Agree re filter, but also consider it may be down to a vacuum leak, split turbo hose or the fuel pump not working properly. The pump is in the tank and will eventually fail, but it is also quite likely the supply for it in the engine relay/fusebox has a burnt pin. See:
    HDI C5 wont start
    Jan 2015
    South Bowenfels
    7
    We were driving down freeway with an external temperature of 30 degrees in the daylight. Thanks for replying
    Jan 2015
    South Bowenfels
    7
    Thanks for taking the time to reply. Have checked all these suggestions. I will get it computer analysed and hopefully I will get a satisfactory result. The car is a bit long in the tooth but looks almost brand new but now worth very little. Not quite ready to retire it yet.
    1000+ Posts garyk's Avatar
    Feb 2011
    1,054
    We had one with huge "melted fuse box/relay" issues that caused failure to start.
    Eventually replaced the unit, but a LOT of dead ends prior.
    Once upon a time:
    Many R4s (incl. fourgonnette), R5LS, R16TS.
    GS 1015, 1220, sedans and wagons.
    CX 2200, 2400.
    ID 1966, 1969, DS21H, DSpecial, DS23 Pallas.
    C5 2002, 2004 petrol and diesel.
    D Special 1974
    Xantia Activa 1998 (look out Gulargambone)
    GS 5 speed sedan (what a tale)
    1986 2CV6
    CX25GTi 1985 auto
    CX2500 IE Pallas 1985 auto
    DS23EFI 1975 Pallas
    And now:
    C5 2.2 HDI 2005 wagon
    DS23 1973 Pallas
