2006 C3 exclusive intermittant fault warning displayed on dash
Results 1 to 14 of 14
    South Australia
    65
    Default 2006 C3 exclusive intermittant fault warning displayed on dash
    We have had an issue with a seatbelt warning message being generated, these can occur randomly sometimes interrupting the radio operation with and an audable beep, apparantly this is very annoying (my son's car) this can happen sporadically eg: continuously going off some days to not happening others
    the connections have been inspected and re-seated to remove surface resistance from the ecu found under the centre console plus under the bonnet the fuse box has been inspected and re-seated.
    has anybody had this problem and if so what was the remedy or has anybody got a wiring/pinout information so we can investigate further??
    C5 exclusive 2008
    Fellow Frogger! Greg's Avatar
    MAITLAND NSW AUSTRALIA
    620
    Hi,
    I think you need to use Diagbox first and see what faults it comes up with. It's always you first procedure, thought its not always the answer.
    best regards,
    Greg
    We Have:
    We Had:
    9,284
    Sometimes, the wiring in the buckle can fracture due to fatigue.
    The sort of thing that can give you an intermittent fault as it is moved.
    DaigBox should tell you the defective location.
    South Australia
    65
    Thanks Greg,
    Have had diagbox access but no faults recorded.
    South Australia
    65
    Thanks David S
    How do you check the buckle wiring ?
    1000+ Posts N5GTi6's Avatar
    1,088
    Wiring connector under the seat ?
    Disable alerting completely in Diagbox ?
    Justin
    '07 C3 Exclusive
    '10 308 Sportium Touring
    '12 Megane RS265 8:08
    South Australia
    65
    Thanks Justin
    Turns out the diagnosys tool that was used is not able to disable alerts, so was wondering if there was anybody close that has a suitable diagbox would be able to help??
    9,284
    Quote Originally Posted by Leanmor View Post
    Thanks David S
    Multimeter? Any belt that as a seatbelt warming should make/break the circuit when the belt is in/out. There were some buckles that had a thin metal strip that suffered fatigue. Try seeing if the connection breaks when the buckle is moved around. When you are fiddling around with the seatbelt electrics, remember the belts may have pre-tensioners that are a pyrotechnic device like an airbag. Reading the fault codes would be the best way to start unless there is something obviously broken.
    CitroŽn Tragic UFO's Avatar
    9,547
    FWIW the electrical connection for the centre rear belt in our C4 has been cut - not by me. Perhaps the previous owner used to carry something heavy on the back seat.
    On the "heavy on the back seat" thing. We once picked up my BiL and his wife in our C5 from the airport and were driving back to Lilyfield and the warning for the centre rear seat was going off. Turns out that Anne's carryon bag was heavy enough to set of the sensors that there was load on the seat and therefore the seat belt should be connected. They plugged in the centre rear belt and all was good. We mocked Anne about the weight of her carry on bag.
    Does your son carry something on the back seat and if so if the seat belt is buckled does the alarm cease?
    South Australia
    65
    Thanks David S
    I will investigate your suggestion, funny thing is when I drove it the other night it did not fire off a warning until I had reached my driveway and that was about a 15 minute drive, when he drive's it he reckons it goes off continuously, now he is 6'3" (old money) and weighs a few more kilo's as I'm only 5'11" and 92 kilo's so maybe the answer lie's there.
    Also thankyou to UFO but he doesn't normally have anything on the rear seat.
    South Australia
    65
    Just a quick question about replacing with new the cost of a drivers side seat belt buckle with pretensioner?? has anybody done this and was it expensive or do i source a 2nd hand unit, and does anybody know where there might be a C3 2006 version that is being recycled/wrecked nearby.
    1,088
    I did exactly this on my Megane. The drivers seatbelt buckle was getting reluctant to release the tongue. I sourced a new complete seat belt assembly from a wreck and installed it. Fixed ! The job did involve removing the seat on the Megane for access, which was the four floor bolts and the wiring connector.
    Justin
    '07 C3 Exclusive
    9,284
    In SA, Martin Bray, Volkstorque?. However, it's a small part and can be easily posted, so perhaps ask forum sponsor French Connection. It probably won't be unique to the C3, so you could get the part number from Citroen Service for your C3 and see which other model it fits if you need to widen your options. It will likely be also used in some Pug models.
    South Australia
    65
    FYI
    Got a quote for a new replacement for the seatbelt stalks, $430.00 wow, decided to go with a second hand unit.
