Citroen C5 X7 door wing mirror
Results 1 to 25 of 25
Like Tree13Likes
  • 4 Post By GreenBlood
  • 3 Post By GreenBlood
  • 1 Post By GreenBlood
  • 3 Post By seasink
  • 1 Post By alhantos
  • 1 Post By shanadoo
Thread: Citroen C5 X7 door wing mirror
    8,012
    Icon2 Citroen C5 X7 door wing mirror
    My drivers side door mirror had an argument with a steel post on Christmas Eve
    Mirror 0
    Steel post 1
    The top section separated from the lower arm, only held together by the wiring loom, I was able to gaffer tape the two parts together until a replacement was found. . .
    After some extensive searching I found a replacement in of all places Lithuania, in my search I found that even with the early X7 there was 7 possible part numbers depending on your car's specification/equipment. A good few Australian ebay possibilities but none with the matching part number and quite expensive. I could get the correct part from the UK but again expensive especially with post added. I understand the part form Citroen is around $900.00 (some assembly required and unpainted).
    The mirror from Lithuania was just over $100.00 delivered, very prompt around 10 days with a public holiday and two weekends thrown in.
    Of course it was the wrong colour so I needed to pull it down and rescue the part I needed. Then do the same with my mirror and make one good from of two. . . My plan of attack was to pull the replacement mirror apart and rescue the part I needed, if I damaged any of the plastic clips etc. it would give me a good idea of the pitfalls for when I pulled my mirror apart.
    So with some encouragement from David S, I set up a clean workspace. . .
    First step is to remove the mirror glass - using the broad plastic tool and levering from the top pops the glass off (so far no broken clips)
    Release the wire connections from the mirror taking note of their positions - depending on the equipment on your car you may have more or less connections here, these look like they would be for the heated glass.
    Next step is to remove the mirror orientation motor (up/down/left/right), three torx head screws (shown in red) releases it one multiplug and it's free.
    The two clips marked in yellow release the rear painted half shell, lots of patience required here, using the plastic tools to hold the clips open whilst pulling and prising the shell away, just when you are about to give up it releases.
    Next release the lower shell, 4 clips shown in above image.
    Now remove the painted front mirror frame, clips are released from the inside I don't have a good pic but they will now obvious.
    This is the part I need, it contains the motor for the folding function when locking the car. It is held to the lower stem by two torx screws (one hiding under a rubber protector. Pic shows the orientation of the harness - the wires feed down a central tube. You see the large multipug for the mirror motor, the two connections direct to mirror, and exterior temp sensor. That temp sensor requires the whole loom to be removed if it ever needs replacement, so the same process as above.
    As they say assembly is the reverse. . .
    All came together nicely, around an hour to pull down the first mirror (with several frustration breaks, so more like 2 hours), maybe only 20 minutes or so to reassemble (the second mirror was much quicker to pull apart 40 minutes or so). I can report no broken clips or damage to paint.
    I'll take a break and show the removal and fitting of the mirror from the door. . .
    Attached Thumbnails Attached Thumbnails Citroen C5 X7 door wing mirror-mirror4.jpg   Citroen C5 X7 door wing mirror-mirror5.jpg   Citroen C5 X7 door wing mirror-mirror7.jpg   Citroen C5 X7 door wing mirror-mirror8.jpg   Citroen C5 X7 door wing mirror-mirror10.jpg   Citroen C5 X7 door wing mirror-mirror11.jpg
    Citroen C5 X7 door wing mirror-mirror25.jpg   Citroen C5 X7 door wing mirror-mirror24.jpg   Citroen C5 X7 door wing mirror-mirror1.jpg   Citroen C5 X7 door wing mirror-mirror2.jpg   Citroen C5 X7 door wing mirror-mirror3.jpg
    seasink, David S, JohnW and 1 others like this.
    08 C5 X7 HDi very Noir
    8,012
    Icon2 Removal refitting mirror/door trim
    To remove the mirror you need to remove the internal door trim. . .
    Disconnect Battery
    Lever the parts shown by yellow arrows, don't forget the light under the door. Disconnect the multiplugs and set the parts aside.
    The door handle hides two torx screws, remove these to release the door trim - pull out from the bottom and lift to remove.
    Identify and release mirror multiplugs and harness, the top arrow shows a cover to the mirror stem - remove
    Not a good pic but you can see the mirror shaft, the mirror is held by a 13mm nutat the end of the shaft - you will need a long shank socket. The socket I have was long enough to sit on the bolt but without the wrench, I had to use grips on the socket to release the nut.
    My fix for refitting. . . cut 5mm from the shaft
    I was then able to use my socket and wrench to secure the mirror - again refitting the trim is a reversal of removal.
    Reconnect battery and test. . .
    All working as it should, the BSI has remembered my mirror setting so selecting memory 1 or 2 changes mirror and seat positions as previous.
    A bit of messing around but not worth making an insurance claim ($750.00 excess and no doubt the parts would be ex France and car off the road for a few days once parts were available).
    Attached Thumbnails Attached Thumbnails Citroen C5 X7 door wing mirror-mirror15.jpg   Citroen C5 X7 door wing mirror-mirror18.jpg   Citroen C5 X7 door wing mirror-mirror17.jpg   Citroen C5 X7 door wing mirror-mirror16.jpg   Citroen C5 X7 door wing mirror-mirror20.jpg   Citroen C5 X7 door wing mirror-mirror19.jpg
    Citroen C5 X7 door wing mirror-mirror23.jpg   Citroen C5 X7 door wing mirror-mirror27.jpg   Citroen C5 X7 door wing mirror-mirror26.jpg   Citroen C5 X7 door wing mirror-mirror29.jpg   Citroen C5 X7 door wing mirror-mirror28.jpg   Citroen C5 X7 door wing mirror-mirror21.jpg
    59 Floride, JohnW and Doush_504 like this.
    St Helens Tasie
    583
    Thank's for the care taken to present this problem. I am amazed at the complexity. I wonder if the "professional" repairers would have been so careful.
    Thank God I'm a Fwenchman harrisson_citroen's Avatar
    Feb 2002
    Coolum Beach
    1,570
    Thanks for the tutorial Chris, plus it'll remind me to be extra careful with my mirrors, now I'm aware of the complexity in removing and refitting.
    It's always a close shave in the dimly lit underground shopping centres carparks.
    DS Un jour, DS toujours !
    1000+ Posts N5GTi6's Avatar
    1,074
    Yep - agree that Lithuania is a surprisingly good source of parts - new as well. 'sm.autoparts' auto parts on Ebay have been good for me.
    Nice documentation on the mirror renewal. I've always been shy about the first step - removing the mirror glass. Is it as simple as pushing a lever in from the top and levering out ?
    Justin
    '07 C3 Exclusive
    '10 308 Sportium Touring
    '12 Megane RS265 8:08
    8,012
    Icon11
    Quote Originally Posted by N5GTi6 View Post
    Justin
    Hi Justin, I've just been advised that the first 4 pics didn't load - hopefully now remedied
    Yes, if you use a broad lever at the top the mirror just pops off without damage. Just as easy when refitting, a push fit. The frustration sets in when trying to unclip the various shells - with several clips for each a second pair of hands would be an asset. I found I could prise one of the plastic tools into one clip holding it open whilst working on another - invariably the first tool would fly across the room and I was back to square one. Perseverance!!!
    It's how I roll...Brisbane
    31,910
    That's a pretty detailed and well thought out how-to demonstration there Mr Greenblood
    It makes one wonder why the designers needed to make it so blinken complicated when most other car mirror changes can be done in a few minutes without even removing the door card( e.g. my Falcon) and $900 for a wing mirror pleez .
    Anyway carry on, how the decidedly special one coming along?
    9,970
    Wow, what a great example of a useful post! Great example of tackling a modern plastic fantastic too. I'm very impressed!
    My thoughts are similar to 59 Floride's response. On my 1950 Renault 4CV the mirrors are held on by two exposed screws. If I want to see something else in the mirror I move my head......
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    Citroën CX Pallas 1980
    1,074
    All visible now - thanks.
    It should be pointed out that most of the work here was due to the need to colour match the painted shell of the mirror. I'm stating the obvious, but if you'd been lucky enough to source an identically coloured mirror then most of the work here wouldn't have been required. We can't always be so lucky with used parts though of course.
    Justin
    '07 C3 Exclusive
    8,012
    Justin
    True indeed, for an investment of just a tad over $100.00 and my time I'm happy with the outcome - Knowing me a black mirror will be on offer as we speak. Good learning curve though and should be useful info for anyone needing to get behind the door card, window motor anyone? Postage from Lithuania was less than sending a parcel across town here and it was sent Priority.
    JohnW likes this.
    8,855
    Not all mirrors have the two connectors. Those that do will have the chromatic glass and memory adjustment, which require additional control lines. The simpler versions may have only the one connector. So, if you are using one of those as a donor, you have to dismantle it to swap the harness over, even if it was the correct colour. Remember, the donor also came from a LHD market, where it was the passenger mirror. Specs vary between markets and where the mirror is fitted. There is also a Saudi version that has different glass and specific markings for that market. Mirrors aint mirrors!
    7,773
    Does the Saudi version make females disappear? Does it matter which glass is pre-fitted?
    8,855
    No, women can (legally) drive there now. And even go to the sport.
    It has an artificial dune horizon and a note saying camels travel faster than you think!
    Actually, I think they are convex glass with specific markings, making them slightly different to what other markets received. I'm sure it would fit, but changing the type of mirror can catch some people out.
    Faulconbridge
    1,697
    Driving the Nullarbor one doesn't see the usual warnings of beware of kangaroos,koalas etc but there are warning signs beware of camels;couldn't help wondering if i'd gone too far.
    shanadoo likes this.
    9,970
    Quote Originally Posted by alhantos View Post
    Near Kambalda, they warn of road trains too. But you surely see THEM coming....
    Attached Thumbnails Attached Thumbnails Citroen C5 X7 door wing mirror-sign-unfenced-road.jpg   Citroen C5 X7 door wing mirror-sign-road-trains.jpg   Citroen C5 X7 door wing mirror-wide-load-eyre-highway.jpg
    Renault 4CV 1951
    Renault R8 1965
    8,012
    Icon2
    Here's another version, I suspect the additional connector on the left would be for chromatic glass, mine didn't have this. Definitely need to get the correct part number if replacing the mirror
    A good write up here, showing replacement of temp sensor, rather than removing the mirror and loom a cut and shut job. . . you may need to translate
    https://www.drive2.com/l/482146570091889165/
    Attached Thumbnails Attached Thumbnails Citroen C5 X7 door wing mirror-c5-x7-photochromatic-mirror.jpg
    Citroën Tragic UFO's Avatar
    9,403
    No, women can (legally) drive there now. .
    Not yet. June 2018
    Saudi Arabia to allow women to drive, under decree issued by King Salman - ABC News (Australian Broadcasting Corporation)
    Mar 2015
    Tooradin Victoria
    198
    I great post Chris but as a "dumb" Peugeot owner I'm confused.............. Wouldn't it have been easier to paint the new Lithuanian mirror to match your car and just attach that?
    8,012
    Icon12
    Quote Originally Posted by DeeCee View Post
    Oooha!, a post on topic
    I did think of that, but to do it properly you need to pull the mirror apart anyway (There are three separate pieces that require painting). Another thought was to vinyl wrap. Both would have added time and cost so I persisted
    Feb 2014
    Sydney Australia
    30
    Hi, on the subject of this mirror, is it easy to pry of the indicator light to replace the bulb ?
    How easy would it be to access the wiring of that indicator? (without removal of the mirror) tx
    8,012
    Icon3
    Quote Originally Posted by Johannes2118 View Post
    I may be wrong but I believe you replace the indicator unit as a whole, I don't think you can just replace a bulb - could be wrong
    https://www.micksgarage.com/d/wing-m...n-c5-2008-2017
    Yes, you can remove the unit without removing the mirror. Around the centre there are two spring clips, carefully prise from the underside (least likely to show accidental damage) and the unit can be released. There is a multi plug that is incorporated into the loom so not great access other than to plug/unplug.
    Attached Thumbnails Attached Thumbnails Citroen C5 X7 door wing mirror-indicator-clips.jpg   Citroen C5 X7 door wing mirror-indicator-panel.jpg   Citroen C5 X7 door wing mirror-indicator-fitting.jpg
    Feb 2011
    brisbane Au
    919
    Well Chris Dr Becker didn't go to all that trouble. One child's dressing table mirror, a blue one seems best, and hold it up whenever you want a rear view. Best idea.
    Of course having no windscreen helps. So short of removing that also, you probably went the right way. Cheers.
    GreenBlood likes this.
    Feb 2014
    Sydney Australia
    30
    Feb 2014
    Sydney Australia
    30
    Great, thanks for the reply and the pics, it is appreciated. Now, all I need to do is find out the type of bulbs used in the Sunvisor mirror as I prefer to replace these with LED ones. Tx again .
    1000+ Posts Bruce H's Avatar
    Apr 2001
    1,183
    If anyone wants an alternative to painting the shells, I have a pair of the "chrome-look" shells that I bought new but never got around to fitting to the DS3 before I traded it. As far as I know, they are identical to this model of C5. Willing to sell for less than replacement cost. Bulky, so postage won't be cheap, but I am travelling Brisbane to Hobart in late November so could deliver along that route then.
    Bruce H
    Now 99 Xantia SX x2; 96 Xantia SX; 78 GS Pallas; 76 GS Club Estate x2; 76 GS Club; 74 GS Club; 88 VW T3 Reimo
    Before: AX Gti; BX 19TRi Estate; CX 2200 Super & Pallas; CX2400 Pallas; CX 2400ie Prestige auto; DS3 DStyle; GSA Club; Xantia Image Estate; Xantia Exclusive; Xsara VTR R4; 1.4 Special Estate; Virage; R16TS
    Contact for the Australian Citroen GS GSA and Birotor Register http://australiancitroengsgsaandbiro...com/index.html
