Citroen C5 X7 U1108 & U1308 error codes
Results 1 to 19 of 19
Like Tree8Likes
  • 2 Post By David S
  • 2 Post By David S
  • 1 Post By dieselman
  • 1 Post By seasink
  • 1 Post By David S
  • 1 Post By harrisson_citroen
Thread: Citroen C5 X7 U1108 & U1308 error codes
    Aug 2005
    Sydney, NSW, Australia
    278
    Default Citroen C5 X7 U1108 & U1308 error codes
    Hi All,
    I am getting error codes U1108 & U1308 on my 2010 Citroen C5 3.0l Hdi.
    Has anyone else had experience in how to resolve/diagnose these?
    I have a Diagbox laptop.
    Thanks!
    Leon.
    Sent from my LG-H815 using Tapatalk
    Leon
    1986 Peugeot 505 GTD (Donor car)
    1987 Peugeot 505 GTD
    1988 Peugeot 505 GTD (For Sale)
    1992 Peugeot Familiale Wagon (For Sale)
    2007 VW EOS TDi
    2010 Citroen C5 3.0 V6 HDi
    8,744
    Any symptoms or apparent downgrade modes?
    They relate to gearbox CAN network communication faults.
    Apparently suspect areas are Engine and auto ECU's and the wiring harness.
    Maybe start with a battery check and make sure there is no corrosion on any of the harness earth points.
    Sometimes, apparent gearbox faults were actually due to a bad relay in the engine slave so you might suspect that, depending on the vehicle mileage and whether there are other faults possibly pointing to a dodgy supply relay in the slave.
    dieselman and electroboy like this.
    Aug 2005
    278
    It has a new battery. The faults also appeared with the old battery.
    Gearbox and ABS fault messages appear on the dash. I think there was a handbrake fault message too.
    I had issues with the Park Lock shunt not releasing, but this was fixed by replacing the micro relay under the glovebox.
    Where is the engine relay you are referring to located please?
    Leon.
    Leon
    2007 VW EOS TDi
    Aug 2005
    278
    Quote Originally Posted by dieselman View Post
    Leon.
    It also goes into limp mode (held in 3rd gear).
    After some time, the fault will go away, but seems to return eventually.
    Sometimes the motor will not crank over.
    Leon
    2007 VW EOS TDi
    8,744
    Engine slave = engine fuse/relay box. Left side of engine bay, towards the rear. A bad relay in the unit can cause a main supply fault and be the source of otherwise unexplained issues.
    However, since you say you have had an issue with the park lock, also look at this:
    https://translate.google.com/transla...4950&edit-text=
    Essentially, where you have found yourself struck in park and have/had these faults:
    P0928: Short circuit to ground or a broken circuit in the solenoid of the shift lock;
    U1108: No communication with the electronic unit motor;
    U1308: No communication with the automatic transmission electronic unit
    Try:
    End the diagnosis session.
    Switch on ign.
    Turn the ignition OFF for 50 seconds.
    Switch on ign.
    Start a diagnosis session without turning the ignition off.
    Clear the error codes.
    Note, this is a TSB being quoted and they are normally VIN-specific.
    dieselman and Greg like this.
    Aug 2005
    278
    Try:
    Switch on ign.
    Switch on ign.
    Thanks for the info.
    My battery terminals had a small amount of corrosion, so I cleaned it off.
    I have already cleared the faults earlier today. This is the first time I have cleared them. I will wait to see if it reoccurs and I will try your suggestion.
    Leon.
    Greg likes this.
    Leon
    2007 VW EOS TDi
    7,480
    The official PSA book may have some help. I'll leave the translation to you.
    U1108 Le calculateur multifonctions moteur est confirmé absent -- Liaison avec calculateur contrôle moteur. CMM est confirmé Absent
    U1308 Le calculateur multifonctions moteur entraîne des défauts fonctionnels -- Incohérence information frein/état de la RVV ou en BVA (Position pédale non émise par contrôle moteur ou Régime moteur non émis par contrôle moteur ou Température eau non émise par contrôle moteur ou Couple non émis par contrôle moteur)
    dieselman likes this.
    Aug 2005
    278
    Try:
    Switch on ign.
    Switch on ign.
    Here's a photo of the left side of my engine bay. I can only see a glow plug relay. Would the engine relay be hidden underneath something?
    Thanks.
    Leon
    2007 VW EOS TDi
    8,744
    It's known as the engine slave, BSM or engine fuse/relay box. Same thing and further forward in your car. The thing with all the fuses in it and a sealed box with relays buried inside. You are not meant to change individual relays as they are encapsulated. However, people do sometimes cut them open and replace individual components.
    Maybe, follow that TSB before spending any money? It's a legitimate TSB that applies to at least some 3.0HDi C5 and someone has placed in the public domain.
    Fellow Frogger! Greg's Avatar
    MAITLAND NSW AUSTRALIA
    620
    Hi Guys,
    Translation:
    U1108 The multifunction engine control unit is confirmed missing - Link with engine control computer. CMM is confirmed Absent
    U1308 The multifunctional engine control unit causes functional faults - Brake / VVC status / Brake status inconsistency (Pedal position not emitted by engine control or Engine speed not emitted by engine control or Water temperature not emitted by engine control or Emissions not emitted by motor control)
    The engine fuse box can cause all sorts of problems, and is known to fail. The replacement box is fitted with larger relays, and believe me, the units inside are not replaceable.
    I replaced the engine fuse box in a friends car just before Christmas. Its a 2013 X7 2.0 HDI. It was coming up with multiple power and pollution problems. The fuse box for all X7's is part no: 98 070 285 80 ($352.78).
    While there is no Guarantee that the fuse box is the problem, you can check the date on the unit in the car, and if its the original, replacement is a good start?
    I tried for about half an hour to pull the old unit apart, and failed to even separate the two plastic halves.
    Best regards,
    Greg
    We Have:
    We Had:
    Aug 2005
    278
    Quote Originally Posted by Greg View Post
    Hi Guys,
    Translation:
    Best regards,
    Greg
    Hi Greg,
    Where did you buy the fuse box for that price please?
    I was quoted over $700!
    Leon.
    Leon
    2007 VW EOS TDi
    Aug 2005
    278
    New battery installed, terminals cleaned and greased with dielectric grease and new fuse box fitted.
    Still getting Gearbox Fault error message occasionally
    Any further suggestions?
    Thanks.
    Leon
    2007 VW EOS TDi
    Thank God I'm a Fwenchman harrisson_citroen's Avatar
    Feb 2002
    Coolum Beach
    1,539
    With a previous C5 X7 (2008) I had had an issue with a number of unrelated fault codes, gearbox, emission etc...on a couple occasions it cut out while driving and would go into limp mode.
    A couple of times I removed the fault and hoped for the best, but kept throwing seemingly unrelated codes and going back into limp.
    In desperation I went to a dealer who instantly diagnosed the accurate cause: Engine Speed sensor kaput. They fitted a new one in half an hour and never had a problem again.
    Sometimes - not always - it's worth a visit to a good dealer!
    Hope this helps.
    DS Un jour, DS toujours !
    Aug 2005
    278
    When I get the errors, I have noticed that the main ECU is very hot on the cooling fins. If I let it cool down, the problem goes away.
    Taking a look at Diagbox, I noticed a stuck power relay control. I don't imagine that this would be normal.
    Leon
    2007 VW EOS TDi
    8,744
    Scroll halfway down this page. Or search for 'Bosch Edc17cp11' :
    https://www.facebook.com/pg/CRACKLEY...4418837/posts/
    and you will see an open ECU of this type, but from a Jaguar 3.0D.
    Assuming it's much the same as in the C5, you can probably get an idea which component is running hot and also where the relay is. It doesn't look too hard to remove the cover and have a look inside. Presumably someone like Injectronics in Melbourne could test/repair it if required as it's going into dodgy DIY territory. I think I'd still be looking elsewhere for a problem before blaming the ECU, which must be the most expensive and least likely item to give grief.
    p.s. Here's the picture to save wading through the awful Facebook page. Not having opened one from a C5, I can't say it's exactly the same.
    Citroen C5 X7 U1108 & U1308 error codes-c5_3.0hdi_jag3.0d_bosch_edc17cp11_ecu.jpg
    Aug 2005
    278
    I just checked my wife's X7, she has the same relay stuck, so it's probably not an issue.
    Leon
    2007 VW EOS TDi
    Aug 2005
    278
    Would anyone have any recommendations for a competent Citroen dealer in Canberra please?
    Thanks.
    Leon
    2007 VW EOS TDi
    7,480
    With all the "disturbance", probably Alan Mackay at Moss Vale. They have had Peugeot for a long time, and now have Citroen also. The workshop has people with some familiarity with C5s.
    Not close, but a reasonable trip up the highway.
    Aug 2005
    278
    So no-one in Canberra?
    Leon
    2007 VW EOS TDi
