DS BvH park brake diagram
Results 1 to 3 of 3
  • 1 Post By GreenBlood
Thread: DS BvH park brake diagram
    skp
    skp is offline
    181
    Default DS BvH park brake diagram
    Anyone have a diagram of the innards of the park brake - particularly the release. Is there any adjustment?
    If so, where? Same principle as the manual gear change, I know, but awkward to find what is going wrong with the one I am dealing with... I SUSPECT that the pushrod has been bent. ( quite HOW that could happen inside the housing beats me, but then the toggle tension spring plate has been bent (!!!) presumably to take the tension off the toggle/ catch. The lower pushrod pivot seems worn, so this may explain why this has been done. Surely there must be some adjustment mechanism...)
    skp
    7,893
    Quote Originally Posted by skp View Post
    skp
    skp,
    Some good pics of the innards here. . . Might give you an idea of what is wrong with yours, seeing the unit broken down and reassembled. Google Chrome allows you to translate the text with each image.
    REMISE EN ÉTAT FREIN A MAIN DS. | Citrothello
    Greg likes this.
    08 C5 X7 HDi very Noir
    skp
    skp is offline
    181
    Perfect, thank you.
