iPhone as a navigation aid.
    St Helens Tasie
    603
    Default iPhone as a navigation aid.
    Anyone use an iPhone as a GPS in a C5 X7 comfort. Mine works OK but there is no verbal instruction when driving with the bluetooth enabled for hands free communication. Does the bluetooth have to be disabled or is there a way of having both.?
    Allan.
    Dec 2010
    Wollongong, NSW
    497
    I have recently used it in a hire car and while it was plugged in to the USB it went quiet. If you pull the usb out, then it became vocal once more. I figure it was trying to use the audio of the radio, but not connecting correctly. Not a straight answer sorry, but it might help a bit.
    Erik
    Member MELso's Avatar
    May 2016
    77
    No problems using Bluetooth here. Have you got the phone paired for music playback? If so, make sure the source on the stereo is your phone and it will broadcast turn by turn directions over the music playing on the phone...
    2011 Citroen C5 - 'La Barge'
    St Helens Tasie
    603
    Thanks, I'l try that . I don't have any music on the phone yet. However I'l switch on the music ap and see if it works with the radio on.
    Allan
    May 2016
    77
    It won’t work with the radio on. The Bluetooth needs to be the source on the stereo to get turn by turn directions broadcast (basically, the Bluetooth just streams the audio output of the phone wirelessly to the car)...
