Citroen CX Auto Electrician
Results 1 to 25 of 29
Like Tree5Likes
Thread: Citroen CX Auto Electrician
    Nov 2005
    57
    Default Citroen CX Auto Electrician
    Hi
    My Citroen is a CX GTi which has an intermittent electrical issue.
    It has been with my usual mechanic for a month and he can't work out what the problem is.
    The car cuts out suddenly when being driven, there is an almighty jerk and then it keeps running again. Sometimes it'll happen all the time other times it'll run perfectly He is convinced that it's electrical but can't trace the problem as it goes away and then comes back. He has checked and replaced all of the wiring, replacing suspect pieces, and gone over the whole electrical system (coils, plugs etc etc) with a fine tooth comb....nothing!
    Can anyone recommend an auto electrician in either Melbourne or the Macedon Ranges who could do the necessary detective work to solve my cars problem?
    Herby
    16,424
    pull the spare wheel out and remove the shrowd under it... big eletrical plugs under here will be dodgy. If it was flywheel sensors it would die for a while there is heat soak under the bonnet ... then work again perfectly.
    Greg likes this.
    Nov 2005
    57
    Sorry, I'm not too mechanical.
    How do I fix it once I've accessed the plug?
    Do I need to replace this plug? Use some contact clearer? Etc?
    16,424
    Quote Originally Posted by HERBYJ View Post
    best fix is to probably chop the connectors out and solder the wires together
    10,802
    I'm presuming it has a coil? I'd check for a break in the low tension wire from the distributor INSIDE the insulation. Not instead of Shane's suggestion, I'd add. It does sound like a key ignition circuit dropping in and out so a connector or a wire. Nothing loose at the back of the ignition switch??
    Do any lights come on in the dash when it cuts out?
    Can't offer more advice. Good luck!
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,928
    How does the tacho respond when the engine cuts out - does it fall to zero or does it stay the same? It is very difficult to track an intermittent fault like this - you almost have to instrument up the car and take it for a drive.
    Cheers, Ken
    IWS
    IWS is offline
    1000+ Posts IWS's Avatar
    Feb 2005
    Hawthorn East, Vic.
    1,319
    Hi
    T&J Auto Electrical 16 Lynch St, Hawthorn
    Phone: (03) 9819 2666
    They are old-fashioned auto electricians and they have experience with Citroen.
    Ian.
    16,424
    Oh ... I was assuming a later injected car. Also check the connections to the tachometric relay ... usually refered to as "big blue".
    UFO likes this.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,069
    Had a similar problem on my 78. Turned out that the fault was in the ignition condenser. Hard to source a replacement locally but ended up purchasing one on Ebay from a Landrover. They have Ducellier ignition.
    Cheers Gerry
    3,069
    Another issue that saw me stuck on the Eastern near Melba tunnel for three hours turned out to be a bad load of fuel and a completely clogged filter screen on the fuel pick up and sender unit. It would sputter and stop and then after a rest would start again only to stall further along the road. By the time we reached the Springvale road over pass it refused to budge any further and ended up getting a ride with Nationwide to my son's place in Seville!
    Cheers Gerry
    Nov 2005
    57
    Hi
    Thanks for all of the suggestions. I think I'll try some of the easier fixes and see whether I can solve the issue myself. If I can't fix it I'll take it to the auto electrician that has been recommended.
    To re-cap.....
    The car is a 1983 CX Gti with fuel injection.
    When driving the car there is a sudden cutting out of the engine and then it keeps going as normal. It is quite a violent shudder which is sometimes there and continuous at other times the car runs perfectly. It can happen at idle or on the freeway, when the car is cold or hot. The tacho doesn't fall or alter as the shudder is so short. None of the dash lights come on when it cuts out either.
    My local mechanic has checked all of the obvious electrical parts, replaced suspect wires, plugs, coils etc etc and can't find a cause. He says it's not fuel, that it's definitely electrical.
    Thanks again for all of the suggestions.
    Herby
    North Brisbane
    1,928
    Herby,
    If the tacho stays pretty steady, then the primary part of the ignition circuit is probably OK. But there could still be an issue with plugs, plug leads or dizzy cap. Otherwise it is in the fuel injection. If it is cutting out at idle, try wiggling all parts of the injection loom and see if you con find any section that is more sensitive than the rest.
    Cheers, Ken
    Greg likes this.
    16,424
    start the car and vigorously shake every wiring harness you can find. I be the car cuts and and dies as you shake one of them. this is the one you need to concentrate on. It will be connectors/wiring harnesses twising as the motor moves in it's mounts.
    Do you have twin transformer coils ... or a standard dizzie with an optical pickup ?
    Nov 2005
    57
    Hi Shane
    i'm fairly sure that I have transformer coils.
    Herby
    16,424
    Hi Shane
    Herby
    Yes ... it's just going to be wiring connectors then .... clean and replace all connector as required and I'm betting it'll be away!
    Jun 2011
    12
    G'day Herby,
    Had much the same problem. with my GTI. Doubtful if your bloke replaced all the wiring. Hope you are a millionaire if he did. Worth checking the connectors to the fuel pump. They are pretty fragile connectors, and lose their tension from vibration of the form. Mine had no tension at all, and were just touching mostly but not always. The Bosch connectors in the plug for the air flow unit give that problem too, for the same reason, also the connectors on the ignition sensors. The forms need to be secured so they don't move the connectors about when they move about. Specially the case with the Air flow unit and the ignition sensor forms. They both need to be tied down. That's the cause of them losing their temper . Bosch used to sell these little connectors in a string but haven't been able to get them lately. They are the same as the ones for the injectors, which they do sell as a unit.
    Easy enough also to remove the ignition sensors and heat in an oven while checking the continuity with some extension leads as they heat up. They give the same problem.
    Good luck. Worth the trouble. Len.
    Jinandfonic likes this.
    16,424
    Make a quick list ... this sounds like an early car with glass fuses under the bonnet, but two tranformer coils and fuel injection.
    --Clean earth point above battery
    --remove both flywheel sensors... and bring to boil in a saucepan of water. There failure mode is generally they stop working when they get some heat soak into them. Put a multi-meter across there pins. They should stay somewhere around 60->100ohms ... they never leap to a high resistance value as they warm up. dependant on which one is failing, you will have a car that completely stops dead.... or one that suddenly runs extremely poorly.
    --find the tachometric relay. They moved it around, I'm not sure of the location on yours (on my '85 modle it's under the drivers side headlight). This powers the fuel pump and injectors while the engine is running.
    --the wiring harness plugs under the spare wheel ...
    --the spade connectors onto the temperature senders across the back of the head.
    --check the glass fuses haven't gone intermittant.
    The last CX2500 I had here would barely run. By just spending 20minutes cleaning the spade terminals across the back of the head and cleaning the big mulit-plugs ... it was instantly fixed.
    If it intermittantly drops back to 2cylinders... or runs on only 2 cylinders... this is a heat sensitive coil ... or dirty wiring connectors onto the coils.
    seeya
    Jun 2011
    12
    Bad connectors to the fuel pump will do that. The connectors are minute, and constant movement in the wiring will destroy the tension of them, making the contact intermittent. The thin sprung Utilux type are better. Not the normal solid ones you get at Supercheap. They are used elsewhere on the CX but harder to find here. I got mine from an Electrical wholesaler in Brendale in Brisbane. Good luck. L.
    Melbourne, Victoria.
    1,389
    And after all of that, I would remove the ignition switch, Dismanltle it carefully, clean all the contacts, check everything, reassemble and test.
    3,069
    Before chopping the wires and re-joining them I would order some electrical circuit board cleaner and liberally spray the blades and spades within each half of the plug. Then I would connect and disconnect the plugs until there is a bright line on each connector blade. Then I would attack the spades with a pair of needle nose pliers to close up the tightness of the spade onto the blade.
    I believe that it is really handy to be able to disconnect this plug during various operations on the car, and would strive to preserve it at all costs.
    Cheers Gerry
    Fellow Frogger! Greg's Avatar
    MAITLAND NSW AUSTRALIA
    617
    Hi Guys,
    Citroen CX's failing to proceed is part and parcel of CX ownership. It was a common problem with every model, right from the beginning.
    Sydney Harbour Bridge was a common break down location in Sydney. CX2500 owners generally had a good book to ready when they stopped and waited for the flywheel sensor to decide to work again.
    C Matics had a faulty earth splice, 2200, and 2400 carby cars it was fuel vaporising on hot days, and early CX's, the radiator hoses fell off the plastic radiator end tanks.......... Oh, and the cars with 100 amp alternators had the diode pack overheat, if it hadn't been moved to behind the grill, and the diodes themselves seemed to need constant replacements.
    But in between, they went rather well (ROFLOL)
    The above will do nothing to help you solve your present problems, but at least you know it isn't just you that has a problem, all CX owners have had them.
    Best regards,
    Greg
    We Have:
    We Had:
    10,802
    Greg, is that what I think it is? THAT is "15/6 H '55"
    Re the not proceeding, I think I have had more stupid trouble with the fairly straightforward Ducellier distributor than anything else on the CX. And the odd green leak of course. Now, electrics seem sorted, radiator recored and it has brass tanks, electric fuel pump, 123 distributor. C-matic is going well.
    I'd certainly agree they didn't do a brilliant job on the wires and stuff!!!
    Renault 4CV 1951
    Renault R8 1965
    10,802
    Whoops. Greg, yours droops at the rear and is a bit long at the front?
    Attached Thumbnails Attached Thumbnails Citroen CX Auto Electrician-citroen-15-6h-2-sml.jpg   Citroen CX Auto Electrician-citroen-15-6h-sml.jpg
    Renault 4CV 1951
    Renault R8 1965
    617
    Hi John,
    Yes we have a 6H. Its needs a lot of body work, it's an ex Molong car. We had one previously, but sold it to Lance Collins (DS Motors). I don't have any pics on hand.
    There were 15 come to Australia. I'm going to convert the suspension to LHM, and fit an Xantia anti sink valve (if I live long enough?).
    This is our previous car:
    Attachment 101692
    This was our 2500 GTI we did a resto on:
    Attachment 101693
    Best regards,
    Greg
    We Have:
    We Had:
    10,802
    Quote Originally Posted by Greg View Post
    Hi John,
    Attachment 101692
    Attachment 101693
    Best regards,
    Greg
    Very nice. What a rarity, a 6H in Oz! I knew a few had come in their day. Our CX is that red too. Anti-sink sounds a good idea - quite a bit of plumbing I guess, to route the pressure pipes forward from the "anti-sink" sphere to the doseur valve.
    I'd better stop my thread hijack!
    Renault 4CV 1951
    Renault R8 1965
