Citroen CX Auto Electrician - Page 2
Page 2 of 2 First 12
Results 26 to 29 of 29
Like Tree5Likes
Thread: Citroen CX Auto Electrician
  1. #26
    skp
    skp is offline
    192
    I had similar issues with my Gti.... an early model without the latter flywheel sensors. After EXHAUSTIVE investigation, it turned out to be a small module sitting above the coil (which itself sits behind the RH headlight). The module transformed a signal from the distributor to the injection system. Turns out they used a similar unit on a number of other cars, and I was able to use one from a Nissan to fix the problem. See if there is a thin two core lead coming from the dizy over to the coil. It's hard to see where this goes, without pulling the headlight out. The small module is bolted to the coil (from memory)
  2. #27
    9,744
    Quote Originally Posted by skp View Post
    I liked the "EXHAUSTIVE"! Every word has a hidden story....
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    Peugeot 306 XT 1995 (daughter's)
    CitroŽn CX Pallas 1980
  3. #28
    South West Sydney, NSW
    236
    My GTi had a similar issue. It would lose power and then die for no apparent reason. Over time it become progressively worse to the point it wouldn't run above 2000rpm. The previous owner had pulled the airbox out and not put it back properly. There was enough movement for the car to receive a huge gulp of air and she would then stall. Wait a few minutes, restart and then it would be fine until the ideal situation and she would die again.
    I know you all suspect electrical, but air can play havoc too.
    Andrew
    UFO likes this.
  4. #29
    CitroŽn Tragic UFO's Avatar
    9,370
    Quote Originally Posted by Andrew D View Post
    Andrew
    Ours would do that too if (ahem) someone had not tightened an airhose clamp sufficiently. The other time was when the concertina hose split radially and the split only "open up" when reversing. Thank goodness for black duct tape.
