2CV Bolt. What were they thinking?
Results 1 to 25 of 26
Like Tree8Likes
Thread: 2CV Bolt. What were they thinking?
    1000+ Posts pottsy's Avatar
    Melbourne, Northern Suburbs
    1,024
    Default 2CV Bolt. What were they thinking?
    As we all know, Citroen are a lateral thinking bunch of Gauls, but lately I've been questioning their sanity somewhat.
    Firstly, I'm aware that there is an element of Citroeniste out there who view any minute variation from "Factory" as deviation of the worst sort and will perhaps react with a degree of pious fervour to my query, however, I've never subscribed to such illogical shenanigans so their protestations will be water off a Duck's back, so to speak.
    There are many areas of 2CV design which have my hand agitating my follicles, but the latest one seems to take the flat baked confection.
    The rocker shafts on the head are held at the top by the head bolts, but at the bottom by a Citroen Special Bolt with a head on it like a diseased pimple. Why is it so? I ask, summoning the Professor from my childhood.
    The head on this bolt is a rounded rectangle 6mm wide and 8mm long. Nominally it requires a special tool to remove and replace. In a pinch one can improvise with adjustable spanners or vice-grips, but we really shouldn't need to resort to these methods. I've had a go at milling out the end of a bolt to suit but unfortunately the ageing motor on the mill threw in the towel. A job for another day.
    The business end of the bolt is simply 35mm of high tensile M8 x 1.25 thread. Experiment and a bit of Internet searching shows me that a socket headed capscrew of the matching thread is a perfectly adequate subsitute.
    The head clears the rocker cover, the function is the same and as a bonus a standard tool will operate it.
    Yet the usual suspects, sorry, suppliers, offer a special tool for this head as a matter of course so obviously people do remove and replace them.
    So can anyone shed some historical light on this conundrum? I doubt that Walter Becchia was such a devious designer that he did it out of spite. Surely there's a reason, but it's really not obvious to this retiree.
    Thoughts people?
    Cheers, Pottsy.
    Buvito Ergo Sum!
    The Fleet:
    2018 C3 Shine ("Oscar" Mrs P's)
    1974 D Special Manual Sedan ("Moby Dick")
    2006 C5 HDI Wagon Auto ("Mephistopheles")
    1982 2CV6 ("Gaston") Seasoned traveller
    1975 GS Pallas ("GiSelle") Next project
    Feb 2016
    North Yorkshire
    106
    pottsy,
    you've hit the nail square on the head, since those peg bolts are a complete PITA.
    Replace with M8 cap head Allen screws, 35mm long, that's all...
    ...except to say, avoid stainless screws.
    It took some time to extract a set of those from a pair of cylinder heads.
    Quote Originally Posted by pottsy View Post
    Thoughts, people?
    Cheers, Pottsy.
    Apr 2014
    Phoenix, Arizona USA
    676
    Quote Originally Posted by Ken H View Post
    pottsy,
    Now I am curious. What happened with the stainless screws? I would think stainless steel, being relatively non reactive would be a reasonable choice.
    robmac likes this.
    John T.
    Fellow Frogger! Trading Estate's Avatar
    552
    Seem to remember that two of the bell housing bolts on the traction are a similar dimension. David Gries had tool that fitted in a socket wrench. It looked like flattened 'cylinder'!
    '04 Megane
    Gone but not forgotten
    '71 16 TS, '72 16 TL, '74 15TS,'82 20TS Series 2, '85 25 GTX. '49 L15,
    Fellow Frogger! neural revolt's Avatar
    Frenchs Forest/Sydney/Australia
    324
    Quote Originally Posted by citroenthusiast View Post
    I think it could be a problem with galvanic action between aluminium and stainless steel. Could this be relevant to 2CV heads?
    I know we had this problem with radar antennas at Sydney airport; the s/s bolts became frozen into the aluminium antenna frames.
    Past Frogs:
    Alpine White 1967 R10 (round eye)
    Alpine White 1972 R16TS
    Blue 1978 Virage Wagon
    Current:
    Red 2009 Clio RS 200 CUP
    Feb 2016
    North Yorkshire
    106
    My guess would be that lethal pairing which is far too common, 'brute force' plus 'ignorance'.
    Whenever I install Allen screws for this application, I use the same torque as specified for the cylinder head stud nuts; 2.5 kgf.m / 18 lb.ft., less an allowance for oiled threads.
    However, it would be very easy for someone who considers torque wrenches to be an irrelevance to apply something close to double that torque...
    Fellow Frogger! andrewj's Avatar
    Margate
    385
    Quote Originally Posted by neural revolt View Post
    That sounds about right to me. It's along time ago, but doing high voltage substation construction, you never had direct contact between stainless and aluminium due galvanic action. Galv to aluminum seemed to be ok through
    Driving - '90 XM, '85 CX IE Auto, 406 Coupe, 405 srdt wagon, '78 dyane, Resting (or Rusting): '73 Birotor '82 CX Presitige, '81 CX Break IE, GS X2, GS1015 Wagon, GS 1300 5sp Wagon, '76 GS 1220 Wagon, '75 GS Wagon, '58 2CV, '58 Vauxhall Velox
    Apr 2016
    Bedford, UK
    708
    Are you any wiser on this Pottsy? On the DS, one (or two?) bolts holding the bell housing to the gear box (or the whole lot to the engine?) have 'special heads'. I'd assumed that these were meant to be 'tamper-proof' but why that would need to be case I can't imagine! I'd also be interested in the reason for your 'special' rocker bolt.
    Feb 2016
    North Yorkshire
    106
    Err, for a galvanic cell to exist, don't the dissimilar metals need to be immersed in an electrolyte?
    If your engine oil is dosed with enough (saline?) water to render it conductive, you've got quite a problem...
    Quote Originally Posted by andrewj View Post
    jaahn likes this.
    May 2014
    104
    Pottsy
    The galvanic voltage difference between two dissimilar metals is given by a chart such as that given in this article: SSINA: Stainless Steel: Corrosion
    Between stainless and aluminium will oxidize (protecting the stainless even more) formed. An electrical path between the stainless and aluminiumneeds to exist and and access to oxygen. Process is accelerated in corrosive conditions.
    In non corrosive connditions it is fine with the galvanic potential barely above aluminium and brass which is pretty universal in engines.
    You might consider the strength difference between stainless bolts and non stainless. It is possible to get Allen headed bolts up to grade 12.9 in non stainless.
    - you will be lucky to get half that in stainless steel.
    I would assume the old citroen bolts to be around 8.8 grade.
    I have the same views on citroen querks - some are brilliant some are questionable - sometimes it takes some time to figure out the category.
    Alex
    Jan 2013
    Geelong
    515
    SS can be a double whammy.
    Apart from the galvanic reaction, has anyone tried to drill SS?
    I used SS rivnuts to attach the floor on an old land rover. Installing them with compressed air always puts a strain on the thread, and, sure enough, one stripped. No way I could drill it out! I had to put a bolt in.
    I shudder at the thought of a SS bolt snapped off in a cylinder head.
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
    Newcastle
    2,622
    Quote Originally Posted by geodon View Post
    Hi geodon
    There are several types of SS and they are not the same properties. I would have to brush up a bit to say more. but generally the corrosion resistant ones are a bit soft but some types are hardenable and can hold a sharp edge in a knife for instance.
    The softer type will "work harden" the surface very quickly if you attack it, with for example, a blunt drill and speed. The surface work hardenes as you go and the drill gets blunter and it all turns to sh*t rapidly as the drill turns blue as does the air The trick is to sharpen the drill first, and then using a slowish speed and pressure and lubricant, ensure it cuts in and does not rub and continues to cut till you are finished the hole. Easy peasy
    Jaahn
    cjl and JohnW like this.
    1,024
    These threads strongly resemble a game of Chinese Whispers sometimes!
    I'm not sure why this degenerated into a discussion on the relative merits of stainless steel over the real stuff, but "knowledge is no burden" as a wise person once quoth so I consider myself further educated.
    Anyway, I've taken on board Ken's wise suggestion of replacement of the diseased pimples with socket heads (normal high tensile steel) and then addressed the creation of a special tool for the removal of said pimples.
    After having a play with the large Mill that recently arrived in the Family, activities were suspended when the aging motor on the big beast decided to take a sabbatical, so milling operations were postponed. My thought was to mill an 8mm x 6mm slot in the end of a bolt, and this is certainly what the purveyors of special tools provide, in essence at least.
    However, sometimes inspiration strikes, so this morning I dug out a bolt of a meaty size and cut a 6mm slot in the end. Naturally I put a nut on first so I could run it back over the thread. after slotting. My thought was that the nut would stop the sides of the slot spreading under load, and this is exactly the case.
    Quite proud of meself actually. It seems to work and will only be needed to extract the PITA bolts anyway.
    Another Special Tool created here at the Bureau!
    In case you want to emulate my creativity, here's a couple of happy snaps.
    Cheers, Pottsy
    Attached Thumbnails Attached Thumbnails 2CV Bolt. What were they thinking?-square-bolt.jpg   2CV Bolt. What were they thinking?-square-bolt-tool-1.jpg   2CV Bolt. What were they thinking?-square-bolt-tool-2.jpg
    baldrick56 and bluey504 like this.
    Buvito Ergo Sum!
    The Fleet:
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,069
    Those bolts are used in Traction bell housings and, also on the front suspension adjusters albeit in a much larger sizes. I know of a fellow who recently purchased an 11BL where the front torsion bars were incorrectly fitted and now that adjuster with the flats sits so far into the cross-member that it cannot be reached with the usual shifting spanner to turn it. And now that he has the need to reset the torsion bars the concept you have "invented" may be of use to him! Thanks Pottsy!
    Cheers Gerry
    1,024
    Hmm. Hold off cracking the Veuve Cliquot, the concept may be slightly flawed.
    I've just tried the fancy new tool on Gaston and I first of all can't move those bloody bolts at all, and secondly both the bolt heads have rounded off slightly and the tool has "opened out" internally to cause the rounding.
    Perhaps I need to start again only this time harden the bolt end first (after cutting of course).
    The other issue seems to have compounded the rounding in that the nut I've used doesn't allow the slot to fully engage on the PITA bolt. (I'm going to adopt Ken's name for them, sounds better than diseased pimple!)
    Sadly, trying an adjustable spanner hasn't worked yet either, so I'll hold off until I come up with a more workable solution.
    Cheers for now, Pottsy.
    Buvito Ergo Sum!
    The Fleet:
    Apr 2014
    676
    Or, just buy a shock absorber stem wrench...
    https://www.zoro.com/cta-manufacturi...CABEgJ0afD_BwE
    John T.
    3,069
    For the ones I have encountered on the TA Bell Housing I have found that I can usually get them undone with a 6mm open ended spanner. Occasionally they have required some encouragement from a hammer and cold chisel! ( of course that approach is to be frowned upon. )
    Cheers Gerry
    1,024
    Well I'll be Mogadored John T! Such a thing actually exists!
    Can't say I've ever heard of it, having always used vice grips or an adjustable spanner on shockers in the past.
    Looks like I may need to investigate further!
    Thanks, Pottsy.
    JohnW and citroenthusiast like this.
    Buvito Ergo Sum!
    The Fleet:
    Apr 2016
    Bedford, UK
    708
    I think you can get brake adjusting sockets that are very similar? John: do you have one of these? if so, are they the right size to go over the end of the Mirex buckles used with Ligarex strapping
    Apr 2014
    676
    The stem wrenches come in different sizes, so you have to get the right one for the particular job. The one I have fits the M7 "tamper proof" bolts used on DS clutch housing and the anti-roll bar clamp. Other sizes may do other jobs.
    John T.
    3,069
    John I cannot get this link to work! All I get is something about the site being blocked in my country!
    Cheers Gerry
    Jul 2003
    317
    https://www.vektools.com.au/lisle-sh...er-socket.html
    I guess this is the tool?
    3,069
    Quote Originally Posted by Harley View Post
    Thanks! I have ordered one!
    Cheers Gerry
    10,802
    Wow. I'd never heard of such a tool. Many thanks for yet another interesting thread.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Apr 2014
    676
    Sorry, I was entertaining family yesterday. It looks like you figured it out, though. If all else fails, you can just Google "shock absorber stem wrench" and get lots of options.
    John T.
