Ds lhs firewall grommet
    May 2014
    104
    Default Ds lhs firewall grommet
    Needing some guidance on sourcing a part.
    It is a grommet that lives behind the lhs suspension cover - attached a photo of the item removed and slid down the linkage.
    The hole in the firewall is 30mm - does a readily available part exist, this is what I have found but cannot confirm they are correct:
    https://www.franzose.de/en/Citroen-D...hoke/ANR35033/
    https://www.ebay.com.au/p/holden-fir...dt=0&rdtsrc=vi
    Any pointers greatly recieved.
    Alex
    Apr 2014
    Phoenix, Arizona USA
    675
    If you mean the boot that fits around the suspension control rod that comes through the firewall, I believe it is P/N D 435-149.
    https://www.franzose.de/en/Citroen-D...riff=D+435-149
    John T.
    May 2014
    104
    That's the one - thanks John
    Ici.
    2,560
    If you have read any of the thread about repro rubber you might be thinking about another alternative!
    May 2014
    104
    Yes the repro rubber and its issues had crossed my mind....also I don't believe the original part is very sturdy being thin at the moving end.
    I have had some sucess in alternatives in other areas. I haven also bought what I believe to be a good quality sheet of nitrile rubber and have been cutting this up into various shapes.
    Hence looking for a wiring harness grommet of correct size....
    Alex
