Xsara boot vents for what reason?.
Results 1 to 8 of 8
Like Tree5Likes
  • 2 Post By Balki
  • 2 Post By dmccurtayne
  • 1 Post By UFO
Thread: Xsara boot vents for what reason?.
    Feb 2011
    brisbane Au
    927
    Default Xsara boot vents for what reason?.
    Some info on Xsara boot vents please ladies/gentlemen/others.
    What are these for in reality? Situated behind the boot side trim on a 1999 Xsara hatch [if model makes any difference] a plastic grill on each side with 2 flap valves now curled up and useless they exit down behind the rear wheel arch allowing dust/road fumes/noise to enter the boot. There's also a grill on each side of the parcel tray supports, presumably to allow the air to exit via the lower flaps.
    What the hell are these for, can I block 'em off?. Never had any cause to investigate anything like this despite lifetime in the trade. Very strange, something new every day I guess.
    8,768
    Tail light access?
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    625
    to make the ventilation system work you have to let air out of the car to be able to get air in
    shanadoo and XM Mechanic like this.
    2016 Cactus
    2003 Range rover l322
    1974 D special
    1971 D special
    1992 CX TGE Safari
    1961 ID19
    1972 DS21 Safari
    1965 Renault R4
    1923 Citroen B2
    1927 B14
    Massey ferguson 550
    Jul 2013
    Newcastle/ central coast
    1,939
    And so you can shut the doors with out popping your ears you can cover them with foam that helps with c5s
    Garage C5 X7 4008
    Fix it right the first time
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,928
    Hi Tony,
    They are supposed to be a one way valve so the flow through ventilation can work. But I guess the plastic flap has lost its soft flat shape that makes thiswork effectively.
    Cheers, Ken
    Feb 2011
    brisbane Au
    927
    Quote Originally Posted by dmccurtayne View Post
    Sounds good to me. Thanks.
    Feb 2011
    brisbane Au
    927
    Quote Originally Posted by Ken W View Post
    Hi Tony,
    Cheers, Ken
    Sounds exactly right although I never made the connection to flow through ventilation. Thought it was something to do with slamming the boot and popping the rear glass. Good idea from dmccurtayne, foam it is. Cheers.
    CitroŽn Tragic UFO's Avatar
    9,721
    FRVs.
    Fart Release Valves.
    dmccurtayne likes this.
