Ds BvH problem
Results 1 to 2 of 2
Thread: Ds BvH problem
    skp
    skp is offline
    211
    Default Ds BvH problem
    I have a BvH car in the workshop. Over the years the pump has been cutting in more often. The pump is Ok, as is the Acca. Clearly there is an internal pressure leak.
    The car has become almost undriveable, as the clutch declines to engage and the steering looses assistance when manoeuvring at slow speeds.
    I isolated the steering, but this has no effect. Not sure where to look next, I decided to look at the return lines.
    The two return lines at the top of the tank come from the Centrifugal Regulator. The rear line has no flow. Good.
    The larger line from the middle of the CR has a continuous flow. It would certainly account for the almost continuous running of the pump!
    Can someone confirm that this line should NOT be flowing while the car is in neutral?
    Skp
    skp
    skp is offline
    211
    Anyone have a spare CR that I can borrow until I get a replacement?
    skp
