Sphere regassing in Melboune outer east
Results 1 to 9 of 9
    Apr 2003
    Nth Dandenong - VIC
    15
    Default Sphere regassing in Melboune outer east
    Hi all,
    Just wanted to let you know I am starting my own sphere regassing service for you crazy citroen owners.
    I have all the gear and just did the rears on my D (including a new diaphragm rebuild). My aim is to offer this at a cheaper rate so you can afford to regas more often and keep the magic carpet running like it's supposed to.
    Spheres must be removed by the owner (can do while you wait)
    I charge $15.00 per sphere for a regas, $30 for a diaphragm replacement an regas on 2 pce spheres (cost of diaphragm extra).
    If you're interested, give me a call on 0411 879 080.
    Rob
    CCV Member
    16,416
    Doh!!!
    I just paid $35bucks each at French Connection 'cos Kirk can't regass the Xantia spheres too
    Fellow Frogger! ajpolden's Avatar
    Apr 2004
    Launceston, Tasmania
    291
    Icon5
    Does anybody know of anywhere in tasmania that will recharge them?
    Apparently the only citroen dealer/service centre in the state doesn't service older models...
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Quote Originally Posted by ajpolden
    FWIW, I live in central coastal Queensland & I send me spheres to Sydney to get them done. It costs about 20 bucks eachway to send a set off a BX, I'd suggest that to send yours to Victoria shouldn't cost much if any more so a viable proposition to post to MisterD
    Alan S
    Apr 2003
    Nth Dandenong - VIC
    15
    Default Sphere regassing update
    Yes,
    send them to me from interstate - no problem.
    I have had the regassing jig for a while but never pursued the regassing until...
    I had to get 4 spheres done in Jan this year. So I go to the guy recommended to me through the club.
    $100 bucks later I've got 4 spheres that "all took the charge well".
    I had two fail straight away. I called and explained this but was told to get new diaphragms and it would cost me $20 to fit plus $25 to regas each. The bit I was most annoyed about is that the regas was not offered for free as the spheres had never worked.
    Anyway, it made me determined to get my regas rig together. Which as just as well as I has # 3 fail. When I took it apart to replace the diaphragm I found it was in good condition - a 4c o-ring was the problem. Something which should have been replaced as a matter of course, but was not. All spheres I do will have new o-rings!
    Rob
    Member josephk's Avatar
    Jul 2003
    east melbourne
    95
    This might sound a bit STEW PED, but how do you know when to regas the spheres. My BX16 Valve seems to behave ok, goes up and down, although the front does take longer than the rear and seems to rise in steps, the groan from the front strut has disappeared( thanks to AlanS ) My question is based on the fact that there seems to be a lot of talk about regassing. cheers josephk
    eugeot 2001 406 Coupe Polo Green.
    :Saab 9-3: 2000 Viggen Convertible Lightning Blue, BSR 424NM frightening!!!
    :Saab 95: 2001 Aero Black Wagon. 184kw .
    :Saab 900: 1993 Classic Convertable Blue.
    $$$ SAVE BANK INTEREST AND BUY MORE TOYS!!
    8,923
    Joseph,
    Not all that hard to check the spheres.
    Press down on each corner (with the engine running & suspension set on normal) & the car will go down just like any other car does. The front will be reasonably firm but should travel a reasonable distance downwards. The 16V doesn't go down as far as other BXs due to the different spheres on the front.
    The rear will be very soft & almost "floaty" even the 16V.
    When a sphere starts to lose its pressure, the distance of travel is reduced and this is noticed in a slightly harsher ride. If it blows or goes dead flat, that corner will be rock hard.
    As a rule of thumb, a sphere with 50% or more left in it is a regassable proposition, however a dead flat isn't as it usually means the membrane is ruptured. Some marginally under the 50% criteria will regas but are a marginal proposition as regards life expectancy. As an example, some BX fronts are blown to 45 bar. 20 bar would be the minimum it would want to be at to expect a reasonable life from the sphere after a regas.
    Most sphere regassers have a gadget for testing pressures before they regas. Experienced ones seem to be able to judge by the way the residue gas comes from the sphere prior to regassing.
    Hope that helps.
    Alan S
    16,416
    Quote Originally Posted by josephk
    Hi Joseph,
    your front struts are binding slightly, that's why it's rising in 'stages'. The front struts are probably making groaning noises as well. Have a look at the strut message just above/below this one in the Citroen forum. There is a lot of suggestions out there for fixing binging struts.
    DS
    DS is offline
    Fellow Frogger! DS's Avatar
    641
    CCC of NSW has been regassing spheres for as long as I can remember.
    There is rarely a club technical day that doesnt revolve around (as well as the BBQ and chats) owners turning up, removing their own spheres and the club regas person of the day regassing the spheres. It has always been a point that the sealing o-ring is a new item as they get hard with age and it really would be a stupid thing to re-use considering they are so cheap.
    It is also not uncommon for someone to remove a sphere from their car only to find that it has been so badly starved of gas that there is little or no gas inside and quite often a ruptured diaphragm.
    Always someone goes home in a car they thought was smooth only to realise they really had no idea how smooth their car was supposed to be until a regas.
