How do you remove a CX Series 2 ignition switch?
Results 1 to 13 of 13
Like Tree4Likes
  • 1 Post By JAJEA
  • 3 Post By leregulage
Thread: How do you remove a CX Series 2 ignition switch?
    Fellow Frogger! leregulage's Avatar
    The hills of Virginia
    136
    Default How do you remove a CX Series 2 ignition switch?
    Does any one know how to remove the ignition switch from a 88 CX25 Auto Prestige LHD?
    I have already removed 2 bolts from around the housing.
    One underneath, the other on the side. It will not slide out of the housing.
    Does the lower cover have to come out?
    I'm kinda squirreled at the moment with the car, the switch broke in such a way it can't be turned to start the car, or barley power it.
    Adam.
    Fellow Frogger! marc61's Avatar
    Jul 2013
    Stamford, UK
    331
    Take the lower cover off and undo the small screw on the side of the cylinder and it should come loose. There are a couple of big connectors that need to be undone that are tucked under the dash (several inches along the wires that come out the back of the ignition switch).
    Once it's out of the way I suspect there's a way of hot wiring the corresponding wires to get the engine running if you don't have a spare switch, but I've not had to do that before so can't advise.
    Cheers, Marc.
    1987 CX GTi T2 Maikonics
    1972 SM 2.7 carb
    1972 DS21 EFI
    136
    Alright then, how does the lower cover come off? I'm stumped on that one.
    Quote Originally Posted by marc61 View Post
    CitroŽn Tragic UFO's Avatar
    9,721
    Is the CX S2 switch like BXs etc that have a detent pin that can only be pushed if you can turn the key to ON? If so, unless you can turn the key then you have to smash the lock out. Likely the internal plastic workings have collapsed from having a bunch of keys swinging from them for years.
    Feb 2013
    451
    Sounds like the steering lock is engaged & obviously you need to turn the key, which you can't at the moment (an anti-theft device that works as intended). It was as you discribe to do once unlocked as I took one off my early CX and it slid out without issue.
    136
    Actually I can turn the key 3/4 of the way ( just until the ignition dash lights come on ). It will not turn any further.
    Is there a detent pin, or more than the two bolts I took out on the switch housing?
    Also, how do I take off the lower panel, under the switch?
    I already have the wheel off and top two phillip on the sides of the lower cover. It is very firmly attached on the left hand side. I cannot see where it is attached.
    Apr 2013
    Essendon
    659
    Adam, You are lucky that you can turn the key to give you ignition and turn the security off. With the advice from others you should be OK,
    You can not turn beyond 3/4 because of the spring loaded mechanism of the starter component of the switch - it is a relatively heavy spring without the key.
    You need to be cautious not to accidently lock the steering as you may have trouble unlocking it without the key.
    Good luck,
    John
    Quote Originally Posted by leregulage View Post
    UFO likes this.
    Jul 2013
    Stamford, UK
    331
    You need to remove the steering wheel first - pull off the centre piece, undo the nut and lift the wheel then the lower cover off.
    Cheers, Marc.
    1972 SM 2.7 carb
    1972 DS21 EFI
    136
    My key goes in and out of the lock just fine. What ever broke has caused the switch to not be able to turn fully on/ start the car.
    I have the wheel off, and the 2 little side screws on the lower cover.
    It is really tight afixed on there! Now this is a USA- CXA modded car. Maybe something is different?
    Bristol/England!
    1,486
    Nah, they wouldn't have altered that... all that citroen andre of holland did was remove the citroen badges, and bring it down to USA standards, mostly running lights, and side reflectors....then market it as cxa.
    136
    Does anyone have a picture of the lower dash, without the cover in place? It is firmly attached on the lower left hand side(LHD car). The right side is loose.
    I see no other bolts, screws on the outside of the cover.
    Unless there is something hidden under the weird little shelf on the left side-by the door?
    16,416
    once you have removed the two dome headed anti-theft screws, it should just slide out.... You have removed the lower console so you can access it and see what is going on
    136
    Hi, thanks for the tips everyone. I just got the lower dash cover, and ignition switch out. Here are the steps I had to do to remove the switch from a 88 Prestige:
    Unhook battery
    Remove Steering wheel
    Remove 10 mm nut directly above steering column shaft (can be seen while sitting in driver's seat )
    Remove screw on left, and right hand side of lower cover (2 phillip screws)
    Lastly, where I had all the trouble there was a bolt hidden by the swing down fuse panel. Once the panel is lowered down, a very thin headed 10 mm nut can be located on the lower left hand side/ on the hood release cable bracket,
    With gentle persuasion, the lower dash should wiggle out of the way.
    Ignition Switch Removal:
    The ignition switch is held in by 3 10 mm bolts
    1 attached to switch itself, the other 2 attached to clamping bracket round switch, column
    The clamping bracket around the switch MUST be removed before the switch is gently slide out to the slide.
    The top bolt does not need to removed all of the way, only merely loosened enough so the slotted end of the bracket can drop down
    Pictures of switch and dash assembly to come
    -Adam
    GreenBlood, UFO and Jinandfonic like this.
