C5 2002 HdI Turbo Auto
Like Tree2Likes
  • 1 Post By seasink
  • 1 Post By gerry freed
Thread: C5 2002 HdI Turbo Auto
    Jun 2003
    Lauderdale, Tasmania
    2,887
    Default C5 2002 HdI Turbo Auto
    I am in the process of changing the timing belt and have hit a silly snag. Must be age or something. How do you access somewhere to clamp the flywheel to get the auxiliary pulley off? Normally one removes a plate ahead of the flywheel and bolts a toothed clamp under the engine. That part of the engine is covered with a solid plate that appears to be part of the engine mounting. I am reluctant to remove it as I strongly dislike engines falling on my head.
    8,768
    Carnets de poche cover distribution well. CARNETS DE POCHE You'll usually find the franÁais more helpful.
    Greg likes this.
    Jun 2003
    2,887
    It has a diagram which resembles a foggy photo that I found on YouTube. It shows the tige going in at an angle. I will look under the car tomorrow.
    Thanks for that. You are right, the franÁais is a great asset when you are trying to work on and buy parts for PSA cars.
    Greg likes this.
    Dec 2010
    Wollongong, NSW
    497
    The later C5 has a hole going into the flywheel in a hard to see spot behind the starter motor that you can put a pin into to pin the engine.
    Jun 2003
    2,887
    Quote Originally Posted by Erikbm View Post
    That was it! I found it from under the car with an endoscope. The picture in the CitroŽn notes was quite misleading as it showed the tool at an unlikely angle. Theirs must have a some curious bends. Mine is quite different but fitted perfectly after I had pushed it into place with one hand while turning the crankshaft with a heavy 22 mm spanner with the other, lying under the sump. Now for the water pump replacement.
