Offset steering wheel.
Results 1 to 25 of 35
Like Tree11Likes
Thread: Offset steering wheel.
    Aug 2015
    Nagambie
    1,969
    Default Offset steering wheel.
    Our new C4Picasso came with a steering wheel offset ~ 10* to the right and the salesman said trying to fix it would "make things worse".
    So it looks like the only way is for me to do the adjustments to the track rods myself.
    Has anyone done it before?.
    And
    The headlights won't adjust high enough from the cabin wheel and that too appears to be too difficult....anymore tackled that from under the bonnet?.
    Once again, ta muchly
    19,095
    If the steering wheel is secured by splines.
    You could correct the "offset" by removing it and rotating to be on centre.
    This is the way I've corrected many off centre steering wheels.
    7,460
    Fine adjustments are usually done on the track rods, coarse on the steering wheel spline. Back to the dealer for me.
    jaahn and CXVingtCinq like this.
    19,095
    In the days of texting abbreviations the big question what is 10* ?
    10 degrees, 10 cm, 10 mm or 10 inches ?
    However, I agree it is the dealer's problem because the alignment has not been done properly.
    8,773
    As Peter said. The steering column is splined, so the wheel can be rotated to another spline. Warning: There is an airbag there - disable it first. Since the car is new I would get in touch with the dealer service manager, not a salesman. You should receive a properly prepared car.They do this small job often in the workshop.
    With the lights, setting them low seems to be par for new cars. Put the cabin wheel at the normal position, and aim the low beam at a vertical surface about 6m away. The back of a hatchback will do, if you have to do it on the road. On each headlight housing there is a plastic Allen key socket. Rotating it with a key will raise and lower the low beam. You want the horizontal cutoffs for both to be no higher than the light centre, and equal. It won't be many turns. There will also be a lit area running off to the left. Setting low looks after high beam automatically.
    Edit: If the adjuster isn't on top, look low down at the back near the centre.
    Another edit: I'm told that two years ago on these it was the white plastic 6 mm hex socket.
    Newcastle
    2,622
    Hi
    +1 for back to the dealer. If there is an offset then after adjustment of the mechanical things, you must do an adjustment of the electronic steering sensor center, as I understand it. This is done using the factory plug in tool, diabox or what ever.
    I would say F**K the salesman, contact your dealers service manager direct and/or Dept of Fair Trading. Also the headlight adjustment.
    Jaahn
    PS a salesman's job is to enhance dealer profitability, not to look after the punters.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,063
    If this car is still under warranty I would be taking it back to the dealer and getting both issues fixed.
    If the headlights are out of adjustment I would say they were not setup properly when new.
    The offset steering wheel could be cause by hitting the gutter, easily done, probably just needs a wheel alignment.
    You can do an easy check yourself for steering wheel being central by making sure the wheels are dead straight and counting the number of turns from centre to full lock is each direction, they should be the same.
    Kenfuego likes this.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Aug 2015
    Nagambie
    1,969
    Back from the dealer today after 5+hr return road trip. Told fixing the wheel would "make thing worse" !
    Yeah right!
    Headline adjustment can't be done either .
    Software update done apparently, supposedly, for sure, absolutely.....why do I bother!
    Aug 2015
    Nagambie
    1,969
    I can't find any fader adjustment for the speakers F to R.
    Only treble n bass and L R balance.
    Surely not!
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,063
    Quote Originally Posted by Nagaman View Post
    Yeah right!
    This may help you with the head lights:
    FAQ : 220 : Manually Adjust the height of my C4 or DS4 headlamps Halogen or Xenon Discharge - C4 - DS4 Owners
    Regards Col
    1973 Alpine A110
    Newcastle
    2,622
    Yeah right!
    Hi Nagman
    It is OK for us to recommend some things but you are not getting proper new service. Go to your motoring organisation for an opinion and recommendation. Join if not a member. In NSW the NRMA will handle this sort of problem. They have technical persons who will give advice and help as well as represent you to the dealers.
    jaahn
    Dec 2005
    Crows Nest, Queensland
    165
    Hi Nagman, go directly to Citroen Australia and lodge a complaint. The new distributors are Inchape. Your dealer well and truly needs a rocket up you know where, preferably an Exocet. Also talk to Joe Patane, their technical services man. He's very good and helpful. His number is 0439-857 787 .
    i have a 2015 Grand Picasso and I needed to adjust the headlights higher. As someone else said, being set too low is the norm. 1.5 turns on the plastic hex socket on each headlight fixed the problem. If they are set evenly now, simply check them against the garage door to make sure you are turning the adjuster the right way and make the same adjustment on each. A simple 5 minute job.
    Cheers, Robin
    Nagaman likes this.
    Fellow Frogger! CXVingtCinq's Avatar
    Jun 2015
    Narrabri, NSW
    986
    Yeah right!
    Abysmal service. Surely they are taking the p*ss. And/or treating you like a country bumpkin. As Robin suggests, you need to contact Citroen Australia and get it sorted. CA should be keen to stamp out such poor service by one of their dealers.
    The dealer must be incompetent if they think they will make things worse by adjusting the wheel. They are admitting they can't handle such a basic mechanical fix.
    JohnW and jaahn like this.
    Cheers, Peter J
    Current - 1974 D Special
    : 1976 16TS
    Previous - 1984 CX 25 IE : 1976 16TS : 1979 12 Virage
    8,773
    The workshops all use beam setters, and most are adjusted low. They will tell you that this is a legal requirement. Raising the low beam aim is simple, and only needs an Allen key. Do it yourself.
    I have a fantasy about your pre-delivery check. The most junior apprentice was sent to check the wheel alignment and nobody told him about what happened to the steering wheel.
    You shouldn't discount using a different dealer for any warranty work. Melbourne or Wodonga, whoever isn't the seller. Should you come north on a trip there are more options.
    Nagaman likes this.
    Aug 2015
    Nagambie
    1,969
    Quote Originally Posted by CXVingtCinq View Post
    Unfortunately it appears to me that the salesman's high handed attitude to the service guys has got their backs up and have put him in his place.....I'm the sufferer though, ultimately.
    These are things that, if the miserable weather was replaced with a bit of sunshine, I could deal with myself.
    I also got the impression the deal was a bit painful for them eg half a tank of petrol and no mats etc.
    6 year warranty is comforting also.
    They're more into selling Kias these days.
    If only Inchcape would demand stand alone PSA dealerships, then we might be taken seriously.
    8,773
    There is a single brand Citroen dealer in Sydney, Continental, whose workshop does know what it is doing. I imagine there won't be more such dealers while Inchacape keeps the range so small. I notice even Continental is selling some old stock Pugs at the moment.
    Aug 2015
    Nagambie
    1,969
    Yeah, it's positively tragic Peugeot/Citroen sales figures and the trend is no better.
    I'm not sure if the Australian is into French subtly either.
    19,095
    Or indeed if French car dealers are into providing excellent customer service to those "unsubtle Australians" either.
    Which could explain the poor Sales.
    Aug 2015
    Nagambie
    1,969
    Well, a Camry wouldn't have a misaligned steering wheel, that's for sure.
    That's the true sign of quality.:wink
    jaahn likes this.
    Aug 2015
    Nagambie
    1,969
    Anyway, there was much apologising and many promises eg: 30% off the first service, a free (unnecessary now) wheel alignment and a warranty extension out to 7 years but on the proviso that they did all the servicing......to be sent in hard copy via snail mail.......after a reminder...still hasnít arrived.
    They major in promises it seems......I get the impression, not so much delivery .
    Seeing there are so many $Ks to be made from so many services (probably twice yearly) youíd think they would look after their bottom line more carefully.
    19,095
    Possibly not. Japanese quality control is generally excellent. And the dealers probably pay attention to predelivery/ service quality.
    However my experience is from a quite a small sample of Toyota vehicles.
    My son has had two Camrys
    My business had four Hiluxes and three Hiaces.
    Our family has owned two Taragos.
    Today we drive something small and fuel efficient, Toyota couldn't entice us with their offerings - but they were considered based on previous, positive, ownership experiences.
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,234
    Nagaman, you should have told the salesman that you bought a Picasso. Had you wanted a vehicle with offset steering and cross eyed lights, you could have bought a Cactus.
    One the other hand, looking at some Picasso paintings, you probably ended up with what you would expect.
    John
    Clogzz likes this.
    19,095
    Perhaps one could say the Picasso was intended to be a bit left of centre. As is it's namesake
    Clogzz likes this.
    Aug 2015
    Nagambie
    1,969
    When it comes to space efficiency it reminds me of my old Austin 1800.
    Jun 2014
    Frankston
    34
    Default Precautions re steering wheel offset
    I'm C5 person not C4 and assuming your C4 has stability control just a word of caution regarding correcting a seemingly minor problem related to steering wheel position.
    The steering wheel provides an input to the stability control system and any realignment of the steering for any reason must be followed up by correction within the stability control program. Basically the system has to know where the front wheels are aimed so that the yaw sensor can determine any deviation from the intended direction.
    This problem is not confined to Citroen indeed any vehicle with stability control requires attention after a wheel alignment without this under some circumstances the stability control system in a real emergency could make the wrong decision with potentially fatal results
