Suspension height? Xantia TD
Results 1 to 7 of 7
    Tadpole paulcof's Avatar
    Apr 2004
    Doncaster UK
    2
    Default Suspension height? Xantia TD
    Hi Guy's
    How Do you measure the suspension height on a 97 Xantia TD LX I am lost as to how to do it .
    Paul
    16,424
    You'll really need to get a manual and read the specs.
    However a simple test with most hydrualic Cit's is a clenched fist will fit nicely above the front tire between the inner guard and tire. The rear is usually right when the wheelspat/guard is lined up in the dead center of the wheel.
    It's a little more difficult with a Xantia. I can measure the height of mine between the jacking points and the ground if you like to give an estimate
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    FWIW, a BX is 160mm between the bottom of the crossmember & the ground (front & rear.)
    How this compares to a Xantia I'm not sure but it may be a rough guide for you.
    Alan S
    10,800
    Yup, it's in the manual. You need one anyway, even if only to decide which jobs never to start!
    1000+ Posts Warwick's Avatar
    Nov 2002
    2,664
    Probably the best measure is whether a human newborn, or neonate if you will, can sleep comfortably between tyre and guard. Suspension will sink after a while, so remember to remove measuring device before too long.
    Mar 2003
    Australia
    101
    Icon4 Xantia Suspension Height Adjustment
    Several months ago i had a problem with my 2.0i VSX Xantia Height
    Below is a Link to my Citroen Site which contains an Excel spreadsheet that will help you re-set the heights, since last time i released this spreadsheet i have made it more user firendly including a detailed picture of what each (L1, L2, R1, R2) setting means.
    NB: Even PSA Citroen suggest that height resetting should be carried out three times to make sure alignment is correct
    Citroen Technical Repairs & Information Site:
    http://www.it-solutions.com.au/citroen/
    I hope this helps
    G
    8,923
    Just stumbled across this while doing something else; any help?
    http://www.andyspares.com/discussion...?TOPIC_ID=3075
    Alan S
