GS Coil
Results 1 to 14 of 14
Like Tree4Likes
  • 1 Post By andrewj
  • 3 Post By graham66
Thread: GS Coil
    Mar 2003
    Location Location
    1,576
    Default GS Coil
    Hello
    GS '72 1015 is running rough, misfiring and gutless under load. Have noticed the (suppressor?)... not sure what function it serves... the thingie attached to the +ve side... is really hot to touch.
    Never noticed it hot like that before. Could the coil be shagged?
    Surprised to see it's a Lucas, not sure if it's pieces d' originale. Cheers for any info.
    8,193
    Icon3
    Quote Originally Posted by graham66 View Post
    Hello
    That's a ballast coil, and yes the ballast can get very hot = normal
    Not sure if a ballast coil is original to the car though, and doubt a Lucas would be original
    08 C5 X7 HDi very Noir
    Fellow Frogger! andrewj's Avatar
    Margate
    385
    Hi Graham,
    From memory, all the GS's I've got have ballast resistors, so assuming original.
    Obvious suspects are pocketing points and/or the condenser. Is it worse on hot days? I had a condenser that used to pack it in when it got hot, only to come good once it cooled down.
    Andrew
    Driving - '90 XM, '85 CX IE Auto, 406 Coupe, 405 srdt wagon, '78 dyane, Resting (or Rusting): '73 Birotor '82 CX Presitige, '81 CX Break IE, GS X2, GS1015 Wagon, GS 1300 5sp Wagon, '76 GS 1220 Wagon, '75 GS Wagon, '58 2CV, '58 Vauxhall Velox
    Mar 2003
    Location Location
    1,576
    Interesting, thanks Chris
    Mar 2003
    Location Location
    1,576
    Hi Andrew, yeah nah, same all the time, regardless of hot or cold.
    I might change the condenser though, see if that makes any difference.
    Margate
    385
    Ha ha, "Yeah but Nah" - haven't heard that from anyone south of Townsville for many years!
    Mar 2003
    Location Location
    1,576
    Andrew just wondering what ign coil is on your 1015.... Ducellier?
    Margate
    385
    let me have a look in the morning...
    Margate
    385
    ok - can confirm the 1015 wagon has a ducellier in it. 1220 wagon has a Bosch GT40. Both have ballast resistors.
    GreenBlood likes this.
    Mar 2003
    Location Location
    1,576
    Cheers Andrew, thanks
    Mar 2003
    Location Location
    1,576
    All sorted, it was the points. Cassette type. S.E.V Marchal.
    1000+ Posts Bruce H's Avatar
    Apr 2001
    1,212
    Glad to hear it's fixed, Graham.
    Spark plugs were done, then I recently replaced the petrol pump on mine when it wouldn't keep running at all, and then with help from Brian B we tried various known-to-be-working-on-other-cars-distributors when mine was found to be running on 3 or fewer cylinders, eventually going back to the original.
    With fresh fuel and warmed up it ran slightly better, but still runs rough and sometimes backfires when cold.
    Unfortunately, I don't use it often enough to currently justify spending any more time trying to fix it. Tonight it will hopefully transport me to the CCCQ meeting, but I'll be taking my phone and RACQ card just in case
    Bruce H
    Now 99 Xantia SX x2; 96 Xantia SX; 76 GS Club Estate x2; 76 GS Club; 74 GS Club; 88 VW T3 Reimo
    Before: AX Gti; BX 19TRi Estate; CX 2200 Super & Pallas; CX2400 Pallas; CX 2400ie Prestige auto; DS3 DStyle; GS Pallas; GSA Club; Xantia Image Estate; Xantia Exclusive; Xsara VTR R4; 1.4 Special Estate; Virage; R16TS
    Contact for the Australian Citroen GS GSA and Birotor Register http://australiancitroengsgsaandbiro...com/index.html
    Apr 2001
    1,212
    Well that didn't happen! When I tried to get it out of the garage tonight it is back to trying to run on 2 cylinders which, not being a 2CV, it wouldn't do
    Bruce H
    Mar 2003
    Location Location
    1,576
    Bruce does yours have the cassette type points?
