1970 id19 sloppy gear lever
Like Tree2Likes
  • 1 Post By badabec
  • 1 Post By GreenBlood
Thread: 1970 id19 sloppy gear lever
    Member cocoelguapo's Avatar
    Mar 2017
    Melbourne VIC
    104
    Default 1970 id19 sloppy gear lever
    Hi,
    Has anyone fixed a sloppy manual gear lever on an ID/DS? I find mine to be a little "loose" feeling. It engages gears no worries but it takes finesse finding the gear slot.
    Feb 2012
    Ongar / England
    811
    Hello, have you checked for play in the linkage at the rear of the engine bay? There are two castellated nuts, top and bottom of a short rod. Once the split pin is removed, you can undo the nut, clean the mating surfaces, grease and reassemble. You need no slop, but not nipped too tight.
    It's the out of focus, over-sprayed in primer, linkage
    UFO likes this.
    8,159
    Icon3
    Also check condition of the gear selector rod for condition of the bushes (black rod from selector to gearbox). . .
    https://www.franzose.de/en/Citroen-D...enge/ANR30262/
    UFO likes this.
    08 C5 X7 HDi very Noir
    9,670
    Also have a look at the pivot mounted on the chassis rail supporting the rod that bolts up to the gearbox. The plastic pivot bush wears out eventually and the thing can become very loose. When you pull the lever towards you or push it away, it's operating a cable that goes to the gearbox and lubricating that may assist.
