DSpecial auxiliary switch for driving lights
Results 1 to 25 of 33
Like Tree18Likes
Thread: DSpecial auxiliary switch for driving lights
    Fellow Frogger! MelanieYlang's Avatar
    Oct 2016
    Wimmera
    320
    Default DSpecial auxiliary switch for driving lights
    Hi all,
    We are trying to find an extra light switch to add to the centre dashboard display panel for the newly mounted driving lights, does anyone have a spare available? We were going to mount a chrome toggle switch, but would of course prefer one to match.
    Melanie
    Sent from my D6503 using aussiefrogs mobile app
    16,322
    You can operate them through relays from the existing (turning) driving lights. These are activated by pushing the light switch in ( from memory ).
    MelanieYlang and Vincenzo like this.
    Fellow Frogger! Dave Rogers's Avatar
    Frankston Melbourne Australia
    259
    Quote Originally Posted by MelanieYlang View Post
    Hi all,
    Melanie
    Would this suit Melanie? If it's any good to you it's yours, PM me your address and I'll post it a Monday.
    Dave.
    Sent from my iPad using Tapatalk Pro
    MelanieYlang likes this.
    74/75 DS23 Pallas 5 Speed Carby
    83 2CV Charleston
    79 GSA
    03 Peugeot 406 Hdi
    01 Renault Scenic
    Oct 2016
    Wimmera
    320
    Thanks to the kindness of Dave, a switch has been organised 😀👍🍻
    Jun 2014
    Frankston
    32
    Hi,
    It is very probable that the current drawn by your driving lights exceeds the switch rating as a precaution fit a relay to handle the current better that than premature switch failure.
    Oct 2016
    Wimmera
    320
    Quote Originally Posted by Hydrac View Post
    Hi,
    Thanks Hydrac, the man about the house had that planned 👍
    Melanie
    8,159
    Thanks Hydrac, the man about the house had that planned ��
    Melanie
    You probably have this covered too, your axillary lights will need to be wired via high beam, i.e. only operate with high beam and not independent.
    08 C5 X7 HDi very Noir
    Oct 2016
    Wimmera
    320
    Thanks Chris, Paul says yep 👍
    GreenBlood likes this.
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,892
    Hey, Don't be too sure about the current required - they might be LED driving lights!
    Cheers, Ken
    Oct 2016
    Wimmera
    320
    Quote Originally Posted by Ken W View Post
    Cheers, Ken
    Don't think that's an issue, Ken, they're old-school driving lights!
    Mar 2013
    olinda victoria australia
    681
    Hi Melanie
    The main driving lights on the DS were switched from the main stalk - there are the normal two high/low beam positions and then to activate the inner driving lights one pushes the stalk in. Only works on high beam, so it is legal.
    Should this still be working on your DS you may not need an extra switch, unless you want to be able to switch the second set independently.
    The switches wear and the first thing to go is often the driving light switching. I looked hard for a replacement a couple of years ago and Der Franzose and the usual suspects didn't have one that did this, but it might be worth checking whether yours is behaving, as it opens up options for making it all a bit neater and easier to drive.
    As always: relays , relays, relays!
    Best Wishes
    Andrew
    Oct 2016
    Wimmera
    320
    Quote Originally Posted by Andrew Watkins View Post
    Hi Melanie
    Best Wishes
    Andrew
    Hi Andrew,
    Yes we wanted to be able to isolate the driving lights, so Paul has installed a relay to be hooked up to the dashboard switch when it arrives, and all the lights are going on and off via the stalk like they are supposed to. Winning!
    Oct 2016
    Wimmera
    320
    Hi Melanie
    Best Wishes
    Andrew
    Andrew, reading this again I wonder if you mean to push the stalk in towards the steering column? This I have not tried yet.
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,300
    Yes, Melanie, push the headlight stalk in towards the steering column to switch the turning headlights on and off.
    Roger
    Oct 2016
    Wimmera
    320
    I'll give that a try next visit! Thanks.
    Mar 2013
    681
    Only works when on high beam
    What I don't know is whether it can easily be fixed if not behaving - mine was on a car that was daily driver, so I couldn't reduce it to 1000 pieces for any length of time finding out and then reducing it to 998 before putting it back and trying to make it work! . Spent the time searching the world for replacement instead.
    There will undoubtedly be people on the forum who do know
    Andrew
    Apr 2016
    Bedford, UK
    666
    Hopefully you will find that your later car has the push-in function Melanie - but be aware that some did not have this by design.
    I once had a 1969 ID 19B basic 'Confort' model. (So the forerunner to the 'D Special introduced in 1970). It had manual steering and fixed lights. Those were swapped outso that it had power steering and the swivelling lights, but I also recall that i had to change the light stalk. I think this was because mine did not have the "push-in" function to operate the second set of lights. I've still got the old stalk somewhere in box. i will have to go and have a look.
    Fellow Frogger! Vincenzo's Avatar
    Aug 2014
    Auckland, NZ
    160
    Mystery solved. I don't have the extra lights and always wondered why that stalk had a 'push in' function...
    DS23 Pallas BVM Vert Argente - in ground up restoration, soon to be BVH.
    DSpecial 4speed Beige Vanneau, previous ; XM 2.0, maroon, my first.
    And a variety of the usual crapboxes before seeing the light. Except my Mini Cooper with the 3.4 cam and twin webers - that wasn't a POS.
    Bikes -
    Ducati GTS860, CB350, XT550, Z500, T250, XR200, ag90.
    Warrnambool
    2,300
    Australian DSpecials were pretty highly specced. Power steering, turning headlights, DS-type trolley brake valve ...
    I never thought I would say this but, having put it in those terms, with specs like that why would you need a DS.
    Roger
    MelanieYlang and Caisson like this.
    Apr 2016
    Bedford, UK
    666
    Quote Originally Posted by Vincenzo View Post
    Vincenzo
    Do you literally mean your car has two headlights and two blank pods where the long range lamps would be? Melanie also seemed to suggest this when she said she was having driving lamps fitted?
    Just curious.......
    1968 DS21bvh Pallas in Gris Palladium
    Restoration blog: https://ds-restoration.blogspot.co.uk
    Aug 2014
    Auckland, NZ
    160
    I got the wrong end of the stick, sort of. I originally thought the accessory fog lights were being referred to. My rotating inner lamps turn on when I turn the stalk onto high. I don't think pushing the stalk towards the binnacle does anything.
    Vincenzo
    Just curious.......
    Bikes -
    Warrnambool
    2,300
    Melanie, if you have decent reflectors on the existing headlights, and you set up the aim correctly (including pointing the turning headlights straight ahead), you might find the existing lights are good enough. The turning headlights are already long range driving lights.
    Roger
    Oct 2016
    Wimmera
    320
    Daphne does indeed have a working push-in switch, which turns off the turning headlights. I just thought that full power was how the headlights are supposed to be - why wouldn't you use them like that? Why turn off the driving lights?
    6,248
    Low beam, high beam, high beam + driving lights.
    2003 PEUGEOT 206 GTi
    Oct 2016
    Wimmera
    320
    Well sure, but why turn off the driving lights ever, if you have to dip them for incoming traffic anyway?
    Caisson likes this.
