DS - New alternator with voltage regulator
Results 1 to 25 of 28
Like Tree9Likes
Thread: DS - New alternator with voltage regulator
    Oct 2016
    Aveiro, Portugal
    14
    Default DS - New alternator with voltage regulator
    Hello all,
    as I was having a bit of trouble with the original alternator + regulator combo on my DS23, I thought I would just buy a new 70A alternator with voltage regulator built-in.
    Now the only problem is figuring out where is the D+ terminal on this thing...
    B- and B+ terminals are identified in the plastic, but D+ is MIA.
    I believe D+ would be the one with the flat terminal (green arrow on the picture), but there's also the possibility of being the round terminal (blue arrow), thus using an eye terminal.
    What do you guys think?
    Thanks everyone!
    18,467
    Blue seems to be ground.
    Green would seem to be ign switched 12v+ via an indicator lamp.
    Knowing the make and model would helpful.
    maxmaniac likes this.
    Fellow Frogger! Le Parisian's Avatar
    Guildford West
    359
    Quote Originally Posted by maxmaniac View Post
    Hello all,
    Thanks everyone!
    Forget the green is an earth just connect the B+ to the positive side of the battery and the green lug goes to the dash light remove all other wires they are now obsolete, good move these alternator works very well and the dash light governs the charging command. Easy installation
    Greg and maxmaniac like this.
    18,467
    Isn't it the blue arrow ground ?
    And the green arrow is the "dash lamp" ?
    The colours chosen are just arbitrary .
    Oct 2016
    Aveiro, Portugal
    14
    Hello robmac, unfortunately, I can't tell the make nor model as it has no references anywhere.
    In fact, it has no references but came with a small testing report detailing the conditions and values regarding rpm, output and losses; still no wiring instructions or something identifying its terminals
    All I can tell you is that it's from franzose.de (if I may write it here)
    Thanks for your input!
    Hi Le Parisian,
    I do know I only need two wires (the large one goes to B+ terminal and the smaller one from the dash light connects to D+), but thanks for stating it again as it reassures what I was about to do!
    You got me a bit confused with the colors, though
    I believe I should discard the blue arrow and use the green one as D+, correct?
    I was inclined to do so, but just wanted to make sure before I set something on fire (which wouldn't be perfect...)
    Thanks for your reply!
    Oct 2016
    Aveiro, Portugal
    14
    Just leaving this here for someone with the same doubts as me:
    --> D+ is indeed the flat terminal (green arrow on the previous picture)
    Member Errol_S's Avatar
    Jul 2014
    Devon. UK
    110
    Hoping I will get a response to this old thread.
    I am looking at purchasing one of these units to replace my failing Ducellier setup. I am confused by D+. What wire are you referring to? My Ducellier has +, EXC and IND. Am I correct in assuming + will go to B+, EXC is no longer required, and IND is the D+.
    Once fitted should I disconnect, or would it be okay to leave, the existing connections to the regulator?
    Many thanks.
    Ici.
    2,494
    check this out Errol, cheat sheet right there.
    Accueil
    Jul 2014
    Devon. UK
    110
    Thanks for that, but I am afraid I struggle to follow those wiring diagrams - all wires seem to disappear into a harness never to be traced again. I can clearly see the D+ on the alternator in the display, but that is not evident on the picture earlier in this thread. I think I need a step by step "for Dummies" when it comes to auto electrics.
    Ici.
    2,494
    you keep the black and yellow sleeve wires hook them up to new alternator and isolate the white one.
    and Bob's your transvestite auntie. Not the bob btw.
    Jul 2014
    Devon. UK
    110
    Ha ha. Thanks for that. I translated your "cheat sheet" into English and get the picture. Slow learner!!
    Jul 2014
    Devon. UK
    110
    Well I have followed the "cheat sheet" to the letter, and my new alternator does not charge. The yellow light comes on and stays on, and there is no charge across the battery terminals.
    This is what I have done on the alternator: Black to B+, Yellow (exc on original) to the spade terminal (green arrow in picture below), and disconnected white (ind on original).
    Then, not mentioned above, but in the "cheat sheet", on the regulator I disconnected yellow (exc) and Red (L) terminals and joined them together. Disconnected purple (bob) and white (R) and isolated them.
    Nada, nothing, no charge. Please help!
    Oct 2016
    Aveiro, Portugal
    14
    Hi Errol_S,
    I'm at work at the moment, but from what I remeber, forumnoreason's reply is the correct one.
    Also, the alternator on my DS only starts charging after 1500 rpm (on the engine), perhaps you should try to rev the engine a bit and see if the situation changes.
    In any case, in a couple of hours I can see how I connected everything on mine and I'll share with you.
    Regards!
    Feb 2012
    Ongar / England
    806
    Hello, probably irrelevant, is the warning bulb an ordinary incandescent type or an LED? The excitation of the charging circuit uses the current through the bulb, so an LED type won't work (it only allows current one way, you need two way). A decent amount of revs can cause self excitation.
    Then again, some alternators are self exciting.
    Jul 2014
    Devon. UK
    110
    Thanks for responding Maxmaniac - hopefully your previous experience will solve my dilemma. Badabec the bulb is stock standard incandescent. I just wonder why the B- on the new alternator had a loose fitting nut, as if it was expecting a terminal to be added. I also find it strange why the B- is insulated from the body of the alternator if it is meant to be grounded. Scared that I might blow a diode (and my money) if I do connect an earth to B-.
    Currently blowing my freaking mind with Annie. Named orphan Annie because she was found under a tree and no one wanted her. Should have left her there!!!
    Thanks all for the advice.
    Oct 2016
    Aveiro, Portugal
    14
    Hello there,
    I just read the thread more closely and the link forumnoreason gave (with french instructions) is the guide I followed back then.
    As the insulation tape was falling apart in my car, I just removed the EXC yellow J11 wire from the installation and connected the red R3 (now using a flat terminal) from the regulator directly to D+ on the alternator.
    The black N2 terminal (big round terminal) is connected to the B+.
    Hope this helps!
    Ici.
    2,494
    two things, is battery low or flat and does your car have a starter relay on the battery?
    I think you should contact Child Protection agency to sort Annie out.
    Jul 2014
    Devon. UK
    110
    Thanks Maxmaniac. That is essentially what I have done by joining regulator exc and L - maybe worth running L (R3) directly.
    Forumnoreason I think I will contact an adoption agency rather. But in answer to your two questions:
    * The battery is fully charged at 13.6V
    * Yes I do have a starter relay on the battery
    Apr 2014
    Phoenix, Arizona USA
    653
    I surmise from your description of the yellow light coming on and staying on (even with the key off) is that your car has a BVH transmission and what you have done is to stumble onto the infamous BVH starter interlock problem.
    There are only two connections necessary for the aftermarket alternator to work. The battery connection (M6 post) and the indicator light (which also provides the initial excitation for the alternator to wake up). To avoid having to splice a wire from the indicator light (L) to the alternator, the cheat sheet commandeers the "EXC" wire to extend the L wire to the alternator. You appear to have done everything correctly, except, you have failed to disable the BVH starter interlock, which is causing the alternator to ground through the ignition switch when the key is off.
    You need to disconnect the ground wire from the wand and provide an independent ground, so that the wand is no longer trying to ground through the (high impedance) lamp connection on the alternator. Once you do that, all will be as it should, except the starter lockout will be disabled, so you will have to be careful not to engage the starter with the engine running. If the alternator has a square wave tachometer output, you can restore the starter interlock by wiring in a common DIN relay.
    The whole starter interlock issue is explained below:
    DS - New alternator with voltage regulator-voltage-regulator-article-a2_page_1.jpgDS - New alternator with voltage regulator-voltage-regulator-article-a2_page_2.jpg
    forumnoreason likes this.
    John T.
    Ici.
    2,494
    you gotta like this guy don't ya?
    citroenthusiast likes this.
    Apr 2016
    Bedford, UK
    657
    I'm not even planning to fit an after-market alternator - and I'm taking notes! Thanks to everyone that's contributed to this one.
    1968 DS21bvh Pallas in Gris Palladium
    Restoration blog: https://ds-restoration.blogspot.co.uk
    Jul 2014
    Devon. UK
    110
    What a comprehensive response and, like Budge, many readers will be thanking you. However I have a BVM and was obviously not very clear about the problem. The yellow light switches on and off with the ignition, however it does not switch off when the motor is running, nor is there any charge registered on the battery. It looks as though I have connected everything correctly, but I will recheck - just in case.
    But why the question about having a starter relay fitted? Is that a potential problem?
    Regards
    Feb 2012
    Ongar / England
    806
    Hello, have you had the alternator checked to make sure it works?
    An auto-electrician can run it up on a test bed and check the output. Or if you have a DC 100amp moving coil ammeter you can can connect this between the battery +ve and the fat lead from the alternator (i.e. in series) then rev it. You should see 55 amps plus. The usual test meters only go to 10amps, you'll blow the fuse in the meter.
    Peter
    Apr 2014
    653
    Nuts, I thought I had solved it for you...
    I am still concerned it may be wiring, rather than the new alternator. A third dash BVM car should not have the battery mounted starter relay. That means you may have some non-standard wiring. Does the car start with the key or do you have a push button somewhere?
    In any event you can perform one more experiment. If you have a volt meter and a piece of wire or test lead, disconnect the Lamp/Exc wire from the spade terminal on the alternator and connect that directly to the battery. This will simulate to the alternator the indicator lamp coming on. Start the engine and observe if the battery voltage goes to something over 14V. If it does, then the alternator is OK and there is something in the wiring. If the battery voltage does not change, then the alternator is defective. If you really want to get fancy, hook a test lamp between the battery and the spade terminal then start the engine. If the light goes out and the battery voltage goes up, then you know the alternator is fine.
    John T.
    Jul 2014
    Devon. UK
    110
    John I appreciate your advice that much that I logged in at 21:20 to see if you had responded - knowing the time differential. You did not let me down. I will however wait for the morning to do the suggested tests. Thank you again.
    I will update tomorrow.
    Regards
    Errol
