C-Matic???
Thread: C-Matic???
    Sans Pond. STALLED's Avatar
    Oct 2003
    2,864
    Default C-Matic???
    Hey,
    Could someone explain to me exactly what is C-Matic???
    Cya STalled
    2005 Renault Clio 182 Cup
    Melbourne, Victoria.
    1,389
    Quote Originally Posted by STALLED
    Hey,
    Cya STalled
    Hi Stalled...a c-matic is a type of transmission which is basically a manually operated gearbox but with no clutch. It uses a torque converter like an automatic, but you still change gears manually. As you move the gearstick a switch disengages the torque converter from the gearbox via an electrically operated solenoid which hydraulically seperates the two. When you let go of the stick once it's in gear, the two re-connect, you accelerate, and off you go.
    Because there's no clutch you could slowly move off in 3rd gear if you wanted to with no adverse affect besides lack of acceleration.
    I hope that's a clear enough description.
    Cheers...George.
    Oct 2003
    2,864
    Thanks alot, cleared it up for me!
    Cya Stalled
    Fellow Frogger! Paul Smith's Avatar
    Camperdown, NSW, Australia
    624
    However if you hear an American talking about a C-Matic they mean a Hydraulique. (they never got C-Matic CXs) That is the semi-automatic gearbox fitted to DS'. It uses a conventional clutch and gearbox with hydraulic control - just like the SensoDrive does with electrickery.
    Paul
    Paul Smith
    1974 DS23 EFI BW Auto
    1974 G Special 1220
    http://www.simplicitas.com.au
    Mar 2003
    Location Location
    1,576
    These c-matics are great - I love this thing I'm driving at the moment. A breeze in traffic. Does the torque converter ever wear out? With no clutch, I take it these things basically last forever - yeah? Great for towing or pulling tree stumps if that's the case
    1,389
    Quote Originally Posted by graham66
    Hi Graham, which of your GS's has the C-matic?
    I found that mine began to work perfectly once I put some Castrol TQF in it , what a difference it made! Suddenly I could change gear as well!
    Cheers...George.
