1960 Citroen ID 19 Steering Rack
Like Tree3Likes
  • 2 Post By gerrypro
  • 1 Post By Frog Envy
Thread: 1960 Citroen ID 19 Steering Rack
    Jun 2016
    Forbes, NSW
    4
    Default 1960 Citroen ID 19 Steering Rack
    Hello to All,
    I am in the process of replacing the rubber dust covers on the steering rack of my 1960 ID 19. Everything was going well up to trying to remove the ball pin from the rack. I just cannot seem to work out how to separate the pin from the shaft to be able to remove it. I think it is pressed on and I might need to apply some heat? Any and all advice would be greatly appreciated.
    8,184
    Quote Originally Posted by Frog Envy View Post
    Hello to All,
    Have a look at this thread, it may save you some grief. . .
    DS Steering rack boots - fitting
    08 C5 X7 HDi very Noir
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,067
    With an ID non powered rack you can remove the steering pinion in order to stretch the new rubber around the pinion housing. In this way the rubber can be fitted from each end of the rack tube with out having to remove the central ball pin.
    Just refit the steering pinion after the rubbers are on. When removing the pinion shaft make sure that you mark the position of the index spline of the shaft against the pinion housing of the rack and mark the position of the ball pin against the rack tube so that everything goes back together as it was originally!
    GreenBlood and Greg like this.
    Cheers Gerry
    Jun 2016
    Forbes, NSW
    4
    Thank you both, Chris and Gerry. Great advice.
    gerrypro likes this.
