DS LHM tank levels
    Feb 2012
    Ireland
    15
    Default DS LHM tank levels
    Hi my ds lhm tank doesn't have any markers on it showing the min and max level for lhm, does anyone know how many millimetres or inches it is from the bottom of the tank to the first minimum mark ? And again from the bottom to the max mark ? If I had the measurements I could make my own marks.
    Thanks!
    8,184
    Icon3
    Quote Originally Posted by darrenhendley View Post
    Thanks!
    _____________________ Bottom of MAXI
    14mm
    _____________________ Top of MINI
    ^50mm from bottom of tank
    Citroen Classics UK have the MINI/MAXI stickers for the unpainted tanks.
    Level sticker for unpainted D Model fluid reservoir
    08 C5 X7 HDi very Noir
    9,774
    To make the hopefully obvious reminder, check the level at the maximum suspension height. Same for CX, Xantia, XM. Not C5/C6, which you check at low.
    Feb 2012
    Ireland
    15
    Brilliant thanks for your quick responses !
