DS23 Vibration / Noise
Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By forumnoreason
  • 1 Post By Errol_S
Thread: DS23 Vibration / Noise
    Fellow Frogger! Errol_S's Avatar
    Jul 2014
    Devon. UK
    121
    Default DS23 Vibration / Noise
    Greetings
    I was returning after a 200km journey in my Pallas when I felt a vibration that I had not noticed before. I thought I was being paranoid and decided it was the road surface. However when I stopped at the next traffic light there was a definite vibration under braking. This vibration was also there when I accelerated from the stop, and this was followed by a cluck cluck noise that materialised from the left front drive train. As I was only 3 kms from home I took it very slow and arrived safely.
    Today I removed both front wheels to ensure that the drive shafts were all secure, and nothing looked loose. I ran the engine in 4th gear but only the right driveshaft appeared to be rotating at speed, whilst the left was hardly moving. Is this normal?
    Any idea of what I should test. I am fearing the worst that the gearbox could be the issue, but I will remain positive that it is something lesser.
    Regards
    Errol
    Los Angeles, CA USA
    1,955
    The 23 has an open differential. Only one wheel will spin.
    Sent from my SM-G930V using aussiefrogs mobile app
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    543
    What condition are your tyres . Can you swap front to rear and road test?
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    Kapunda
    457
    If you want the LHS D/S to turn refit the RHS wheel and lower it to the ground.
    woody
    Fellow Frogger! Le Parisian's Avatar
    Guildford West
    359
    Quote Originally Posted by brian woodcock View Post
    woody
    Sounds like an engine mount
    Dec 2010
    Wagga Wagga
    347
    H frame cracked?
    Jul 2014
    Devon. UK
    121
    Thanks for the suggestions. I will check each of those. I will also pull on the handbrake and move the wheel back and forth to see what play there is on the universals.
    Once the fault is identified I will update this post.
    Ici.
    2,560
    I bet it's your engine mounts aussi! Is it an efi or carby, if carby a quick check for mounts is if you can get a plug socket spanner down the 4th cylinder tube. If not possible mounts sagged and engine is out of alignment, hence vibration. Anyway just a wild guess but still.
    Jul 2014
    Devon. UK
    121
    Okay I have checked all the suggestions. Engine mounts sound. No cracks on the H frame. Tyres good. As Brian suggested I lowered the right wheel to the ground and ran the engine in gear. The left drive shaft was not running true so that explained the vibrations. The noise was also apparent. I found that there was excessive play on the drive housing / tri-axle, so suspect that this may be the culprit.
    This can only be attempted over the weekend, so there goes my super rugby.
    Ici.
    2,560
    watch the rugby! I bet it's your triaxe!
    Vincenzo likes this.
    Jul 2014
    Devon. UK
    121
    Turned out to be the triaxle as suspected. Although there were no ruptures in the boot the amount of grease present was no more than a table spoon. Fortunately the wear and tear was no more than expected and a good greasing, and replacement of the boots while stripped, was all that was necessary.
