C5 2.7hdi 2009
Results 1 to 13 of 13
Like Tree2Likes
  • 2 Post By UFO
Thread: C5 2.7hdi 2009
    Jun 2016
    Perth
    16
    Default C5 2.7hdi 2009
    Hi all,
    i noticed a fan belt type constant squeal that started intermittently then grew in sound and is now pretty much always there and loud. It goes away once your accelerating and mainly happens at idle.
    im guessing it's a water pump cause I sprayed wd40 on the belts and there was no change(hope wd40 is ok but had to try that to eliminate the belt being the problem).
    my questions are:
    1. Is it dangerous to drive it like that IE will the timing belt destroy itself etc? Can I drive it noisy for a while?
    2. How much to change a new water pump?
    3. Is it best to do the whole lot while doing that job IE Timing belt, water pump, tensioners and anything else while it's all apart??......What would that cost?
    many thanks for info
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,925
    The timing belt is due by 2018 at the latest anyway. I would replace water pump and idlers when belt is replaced. If the water pump seizes you will do massive damage to the engine - cam followers, maybe camshafts and valves so get the work done ASAP.
    You will just have to get some quotes from Cit and Peugeot mechanics.
    Cheers, Ken
    16,414
    You could try your local ford and land rover dealers too ... the same engine is used in Territories and Discoveries.
    It would be interesting to see how much the same belt kit is through Poogoe/Citroen/Land Rover/Ford.
    CitroŽn Tragic UFO's Avatar
    9,719
    Can you imagine the reaction if you turned up at most Aussie Ford dealers with a Citroen? {work of the devil, crap engines, bloody hydraulics, they're all built with left hand threads} etc etc etc....
    Then point at the engine.
    jaahn and Vincenzo like this.
    Fellow Frogger! Greg's Avatar
    MAITLAND NSW AUSTRALIA
    617
    Hi Guys,
    EAI is probably you best bet for the parts, they are in Sydney & Melbourne. The problem might just be the tensioner pulley on the serpentine belt. Take the belt off and see how well the tensioner turns. Think there is two rollers on the 2.7 HDI? If its not there then its probably in the timing belts (tensioner or water pump)
    Best regards,
    Greg
    We Have:
    We Had:
    Oct 2015
    Burwood Melbourne Australia
    23
    The SKF VKMA Kit available at EAI for about $450 contains the required belts and pulleys. Yes, you should do the water pump at the same time.
    I have recently done mine in the 407HDi coupe.
    Not sure how the engine is mounted in the C5, but the 407 has it across the car whereas the Territory and Land Rover is aligned with the fore and aft direction. Access is completely different.
    Fellow Frogger! flipperman's Avatar
    Oct 2012
    Melbourne, Victoria, Australia.
    413
    Hi frednierck was your 407 done by a pug dealer or local guy, the reason i ask is my quote to do the job is $2,000.00. $1,600 labor and $400 for the kit which includes doing the water pump. If it was a local garage are you happy with the job and price?
    CitroŽn's that own me
    - 2008 C5 X7 Tourer (Estate) 2.7 DoubleTurbo Diesel UHZJ - V6.
    CitroŽn's that formally owned me
    - 1990 BX TRI Estate Manual. .. . "Phoenix" - "Donated to Science"
    - 1990 BX TRI Estate Auto. (Traded In)
    - 1987 BX TRI Hatch.
    Australian Citroen BX - All about the Citroen BX in Oz
    Oct 2015
    23
    Quote Originally Posted by flipperman View Post
    Performed by my local mechanic with whom I have a long term business relationship. Has maintained the boss's Laser, Astina and 307 and my Magna over many years.
    Job was done as part of the major service, but the line item says " Replace engine timing belt, tensioner and idler pulleys, replace injection pump belt and tensioner-9 years/180000 kms. $1020. The water pump had been replaced after an emergency failure up at Wipenna Pound in the Flinders Ranges.
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    624
    Check your alternator clutch pully for squealing
    Via the aussiefrogs App
    2016 Cactus
    2003 Range rover l322
    1974 D special
    1971 D special
    1992 CX TGE Safari
    1961 ID19
    1972 DS21 Safari
    1965 Renault R4
    1923 Citroen B2
    1927 B14
    Massey ferguson 550
    Jun 2016
    Perth
    16
    Thanks for all your input people. Will get it checked out
    Oct 2012
    413
    frednierck - Thanks for the info
    Quote Originally Posted by C5Tourer View Post
    C5Tourer - Don't use WD40 next time use Silicon Spray
    617
    Don't use any spray.......fix the cause of the squealing, not hide it, and belt dressing usually only makes the problem worse.
    Best regards,
    Greg
    We Have:
    We Had:
    Oct 2012
    413
    Quote Originally Posted by Greg View Post
    Greg
    I did mean as a short fix for a few days until your booked in to fix it.
