petrol tank clean
Results 1 to 7 of 7
Like Tree5Likes
  • 3 Post By 59 Floride
  • 2 Post By Mitchell
Thread: petrol tank clean
    600
    Default petrol tank clean
    Any tips on cleaning a petrol tank that has been sitting for a long time and has filled the petrol pump with gunk,
    it is now out of the car to make things easier
    It's how I roll...Brisbane
    33,182
    Strap it to a cement mixer, fill with sharp gravel, detergent and water.
    https://youtu.be/ULKCqQfRZzI it works.
    Member Mitchell's Avatar
    Perth
    97
    I'd recommend one of the fuel tank liner kits - often sold through motorcycle suppliers.
    These are typically a two part process of cleaner and a liner.
    This kits will clean the tank and stop future service issues, as debris from earlier corrosion, slowly releases into your fuel system.
    Rhys
    dimistyle and Dano like this.
    Brisbane Australia
    162
    I have done two traction tanks, both, with a POR Fuel Tank Kit. (https://www.youtube.com/watch?v=u0tkcipLxpY)
    It is not the cheapest way of doing it but if done properly you can fill and forget. Special attention needs to be paid to getting the finish coat everywhere inside bearing in mind the tank will almost certainly be baffled. Cheers.
    Jun 2014
    Sydney, NSW
    239
    I'd recommend both, 1st clean with a couple of garden trowel fulls of gravel. (I bought a sack of 'bluemetal' about 10mm fraction), didn't use a concrete mixer though - just agitated by hand. Tip out, repeat x2 minimum. Then I used a tank seal kit (KBR coatings was one I used), main problem with that is you have to rinse out tank after 'stage 1' then has to be completely dry for coating application. I rigged up a hairdryer blowing into the sender unit aperture- still takes about a day to dry
    may all your plans be cunning ones,
    Baldrick,
    fleet: 1989 Peugeot 505 GTi Wagon
    1969 Peugeot 404 Sedan
    2003 Smart 452 Roadster
    2005 MG ZR160
    1988 Mercedes 300E
    1953 Citroen 15CV (under Restoration)
    1953 Bristol 401 (under Restoration)
    That's one for each day of the week - I really should stop
    Apr 2003
    385
    If you have a water blaster( Karcher/Gerni or similar) give the accessible internal surfaces a good blast before the gravel treatment...it will remove a good part of the built up crud far more quickly.
    Take care to note if there is an internal mesh strainer in your tank..it may be ruined by either / both of these approaches.If so remove the strainer mesh and place an extra in line filter outside the tank.
    John
    1000+ Posts driven's Avatar
    Apr 2005
    1,444
    Will need to clean with chemicals otherwise tank seams will retain junk and fine rust
    As good as any
    Petrol Tank Cleaning and Rust Removal - Real Classic Motorcycle Techniques
