C5X7 Diesel fuel filter
Results 1 to 8 of 8
Like Tree3Likes
  • 1 Post By XM Mechanic
  • 1 Post By UFO
  • 1 Post By dcc236
Thread: C5X7 Diesel fuel filter
    Dec 2016
    camden
    36
    Default C5X7 Diesel fuel filter
    Can anyone tell me where the fuel filter is located on 2009 C5 X7 sedan.Thanks
    Sydney, Australia
    306
    Would this vehicle have 4 or 6 cylinders? What capacity too? 2.0 2.2 2.7 or 3.0.
    They all appear to be under the bonnet.
    UFO likes this.
    Garth.
    Fixin' Cit's.
    '19 308 GTi
    '15 DS 5
    '74 GS Convertisseur
    In the family
    '51 Traction
    '08 C5 X7 V6
    Previous ownership
    '95 XM V6 Series 2
    '96 306 XTDT
    Dec 2016
    camden
    36
    sorry Garth. I should've said it's a 2.0lt HDI 16 valve. not sure if it's the 100kw or120kw.
    8,763
    Front of engine, driver's side, high up. A large black cap with a hex top on the RHR engine. It takes a bit of force because of the O ring, so use a hex socket. There was a tool thread on this. The fuel lines lead in and out.
    Dec 2005
    Crows Nest, Queensland
    165
    Not sure about the 4 cyl diesels, but the 3.0l V6 HDi I owned also had a fuel filter attached to the rear vertical surface of the fuel tank. i know because it fell off!! Fortunately the fuel leak was minor, but Citroen replaced the fuel tank, filter and mounting under warranty.
    Robin
    CitroŽn Tragic UFO's Avatar
    9,721
    Engine bay as described above. Use gentle pressure undoing the filter top, not sudden force. Same as removing the oil filter cover.
    Greg likes this.
    Oct 2014
    Brisbane/Australia
    372
    Greg likes this.
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,927
    I bought a half inch drive six sided impact 27mm socket and then used the grinder to make some small U indentations so it sat down better on the top of the fuel filter. This was after I almost took all the edges off the nut using a normal ring spanner.
    Ken W
