DS 19 positive or negative earth ?
    Nov 2011
    87
    Default DS 19 positive or negative earth ?
    Not sure if my Slough built DS19 is pos or neg earth ..... finally going to fire her up tomorrow - thanks
    16,414
    Um ... short the starter and see if it spins backwards or forwards (with jumper leads of course ... without hooking up the battery terminals. You don't want to fry any gauges
    Roger Wilkinson might know. Failing that, chase up Buttercup Bobs phone number and give him a call!
    Dec 2001
    Tasmania
    111
    Quote Originally Posted by andyk View Post
    Likely to be positive earth. My 57 is and the 58 Slough ID is the same.
    Nov 2011
    87
    Ok thanks guys for your input ..... mines '57 so most likely positive
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,344
    Likely to be positive earth. Mine is 1959 and positive earth. You can tell by the size of the battery terminals. Negative is smaller than positive so check whether the smaller or larger one goes to earth.
    I have never bothered to change it. The only time it is an issue is powering a radio that gounds to the chassis, and I don't use radios in Dees.
    Roger
    Nov 2011
    87
    Ok thanks Roger for the info .... will get it sorted today
