D Super Minor problems
Results 1 to 8 of 8
  • 1 Post By mberry
Thread: D Super Minor problems
    Kapunda
    457
    Default D Super Minor problems
    Took the Super for its first run yesterday (for me that is) having travelled about 80k I noticed the Ign key was quite hot when I stopped the car.I had no accessories turned on .When I checked this morning there was a voltage drop of 1.3 v to the coil ,harly enough to explain the very hot Ign Switch.
    Secondly I plan to fit some Balancers to the drive shafts,does anyone know the best place to fit them?
    Woody
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,062
    Quote Originally Posted by brian woodcock View Post
    Woody
    I would say that there is a bad connection in one of the contacts of your ignition switch, you either need to dismantle the ignition switch and repair it or replace it with another that is known to be good.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Jan 2017
    mulgrave
    72
    Brian,
    By D Special does not have balancers on the drive shafts. There is no vibration at speed but should I put some on?
    Regards
    Ian Downie
    Blueduck (aka Ian Downie)
    1974 Citroen D Special with DS21i.e. engine and 5 speed gearbox
    MGB GT V8 B.... bullet--proof and great fun
    Jaguar e-type roadster ... on the way from US of A
    9,774
    Damper fitting instructions are in the manual, but from memory, the diagram was mislabelled for L&R, so common sense prevails when reading it. For a car just used around town or at moderate speeds, the benefits of having the dampers may not be great.
    Kapunda
    457
    I,m getting some vibration at low speed so I may be wasting my time,no harm done however.
    Woody
    Ici.
    2,560
    I thought they were only on 23's?
    Mar 2011
    Broom
    816
    I have heard that the dampers have no noticeable effect, so if you are getting a vibration, I would be checking the wheel alignment/camber first. But as stated the measurement for the dampers is in the manual.
    P.S. I reckon my ignition key always gets pretty warm.
    GreenBlood likes this.
    8,184
    Icon6
    Quote Originally Posted by mberry View Post
    Agree 100%, I've had cars with and without the dampers and unless you are really fanging on a very smooth road you wouldn't pick the difference - it's a given both cars should have balanced wheels and tyres which will show a difference if out of spec.
    . . .and yes to tepid to warmish ignition key
    08 C5 X7 HDi very Noir
