Oil pressure switch for D Special.
Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By GreenBlood
  • 1 Post By Bad Bertie
Thread: Oil pressure switch for D Special.
    3,581
    Default Oil pressure switch for D Special.
    I have an oil leak, and I believe it's from a faulty oil pressure switch. Had a similar problem years ago with another D. From memory I was told by someone a new one from a Holden was the trick. True or false?
    19,092
    8,184
    Icon3
    It's a Citroen Rob, you know 'has to be different' - requires M10 x 1.5 pitch, I can't see anything in Tridon range.
    Common consumable part though, can be had through the usual Aus suppliers - DS Motors/ Roger Parker etc. Or OS Oil pressure warning switch - all models from 1966 onwards
    They don't normally leak, they gush
    08 C5 X7 HDi very Noir
    19,092
    At nearly 12 quid each plus freight . I'd make an adaptor m10 1.5 male to 1/8 gas male (possibly available) and use a Tridon.
    For about $20 plus freight you have some scope.
    Apr 2013
    Essendon
    660
    I was about to say Bert I've got one in my garage left over from my Simca days and all you are going to need is a copper washer if I can find it!
    Found it! B* *#dy thing is 12 x 1.5 - want to borrow 12 mm tap? (Just joking.)
    I concur with Rob in any case; cut the top off, drill 11/32's and tap 1/8 gas.
    John
    3,581
    Thank you all for your input , but am not willing to tap and drill.There must be one available locally somewhere. I,ll take the old one out and shop around!
    8,184
    Icon11
    Quote Originally Posted by Bad Bertie View Post
    Give Lance at DS Motors a call, he'll have it in an Express bag overnight to you. . . buy two, a good spare to have on hand and will ensure you'll never need it
    Vincenzo likes this.
    3,581
    Thank you Chris, i shall keep that in mind if i cant get anything local.
    3,581
    All sorted! Got my switch from European Auto care in Penrith. Denton Christie also got me an regulator return hose which was badly needed. All good reception from that place!
    GreenBlood likes this.
    Ici.
    2,560
    was the return hose the source of the lhm leak you were experiencing BB?
    3,581
    I believe so. The previous owner did a band aid job before I picked it up, just to keep the car rising. The original one perished years ago,and he kept it all those years! And the one on the car was a two piece job he did when the original carked it. And I found that the original hose has different sized openings at either end. Denton adviced me to get a GS return hose which he says are far more durable, and will fit straight on. So, hopefully, no more leaks!
    Ici.
    2,560
    Finally I got one right! Denton was always plugging that hose as a first stop culprit to me back in time. And that GS hose tip is good as I was thinking exactly the same thing. Cheers
    Steven
    3,581
    Steven
    Yeah, the GS one is more than twice as long, and rather chunky, about the size of adult brown snake! should be easy to fit with a coil in the centre!
