SM vs DS IE clutch
    Apr 2014
    Phoenix, Arizona USA
    674
    Default SM vs DS IE clutch
    The part numbers for the SM clutch disk and the >72 DS IE clutch disk are the same 5 432 504, however, the clutch mechanisms have different part numbers. Does anyone know offhand what are the differences? I am curious whether you could fit an SM clutch mechanism to a DS IE or vice-versa.
    John T.
    9,769
    A total guess, but if they are not the same part and in the absence of any obvious difference, possibly the spring clamping pressure may be greater for the SM's more powerful engine. It may be mentioned in the technical data books somewhere.
    Fellow Frogger! marc61's Avatar
    Jul 2013
    Stamford, UK
    331
    Quote Originally Posted by citroenthusiast View Post
    Hi John,
    I'm not sure exactly what you mean by clutch mechanism? The fork, dust boot etc are the same.
    The slave cylinders are different between the BVH and SM - I've often wondered why they didn't just use the BVH slave cylinder on the SM.
    Marc
    Cheers, Marc.
    1987 CX GTi T2 Maikonics
    1972 SM 2.7 carb
    1972 DS21 EFI
    Apr 2014
    674
    Quote Originally Posted by marc61 View Post
    Hi John,
    Marc
    Hi Marc,
    I was just using the language from the parts manual. The "clutch mechanism" is what I would normally call the pressure plate. The SM can't use the DS slave cylinder because the DS slave cylinder doesn't have any provision for bleeding.
    John T.
    Jul 2013
    Stamford, UK
    331
    Ah I see. It's probably stiffer springs like David suggests I guess.
    Cheers, Marc.
    1972 SM 2.7 carb
    1972 DS21 EFI
