Speedometer with LED bulb
Results 1 to 13 of 13
Like Tree7Likes
  • 1 Post By turbofiat124
  • 1 Post By Ken H
  • 1 Post By Greg
  • 2 Post By Vincenzo
  • 1 Post By Pierre Boulanger
Thread: Speedometer with LED bulb
    Member turbofiat124's Avatar
    Jan 2017
    Hawkins County, TN, USA
    74
    Default Speedometer with LED bulb
    Thought I would post a photo of my speedometer with an LED bulb. The original incandescent bulb had not burned out but the glass had turned black. I couldn't even see the needle to know how fast I was going or the reference marks when to shift.
    CEyssens likes this.
    1987 2CV faux Charleston edition (One of many other makes)
    Mount Carmel, TN. (Outside Kingsport) USA
    http://s222.photobucket.com/user/turbofiat/library/Citroen%202CV?sort=2&page=1
    Feb 2016
    North Yorkshire
    106
    Although, if you read the Owner's Manual supplied by Citroen, those marks were not intended to be used as a guide for gearchanges, but were only applicable during the running-in stage.
    First page.
    During the first 1,000 km, do not exceed:- 20 kph in 1st gear, 45 kph in 2nd gear, 65 kph in 3rd gear & 90 kph in 4th gear.
    Page 38.
    During the first 2,000 km, ...do not let the speedometer needle reach the coloured marks.
    "I couldn't even see the needle to know how fast I was going or the reference marks when to shift."
    Dave Rogers likes this.
    Fellow Frogger! Greg's Avatar
    MAITLAND NSW AUSTRALIA
    617
    Hi Ken, they are the reference marks when to shift?
    There are at 40, 60 + 80.
    Your quotes from the owner manual are 20, 45 & 65?
    best regards,
    Greg
    617
    BTW,
    Instruments look great........What led did you use?
    Fellow Frogger! Vincenzo's Avatar
    Aug 2014
    Auckland, NZ
    162
    Quote Originally Posted by Ken H View Post
    do not exceed: ..... 90 kph in 4th gear.
    Does the 2CV have an inclinometer to tell you how steep the downslope is? [ducks]
    HONG KONG PUGGY and jaahn like this.
    DS23 Pallas BVM Vert Argente - in ground up restoration, soon to be BVH.
    DSpecial 4speed Beige Vanneau, previous ; XM 2.0, maroon, my first.
    And a variety of the usual crapboxes before seeing the light. Except my Mini Cooper with the 3.4 cam and twin webers - that wasn't a POS.
    Bikes -
    Ducati GTS860, CB350, XT550, Z500, T250, XR200, ag90.
    Jan 2017
    74
    Quote Originally Posted by Greg View Post
    BTW,
    10 PCS Lots White Light Super Bright 12V T11 BA9S 5050 SMD 5-LED Car Bulb Lamp
    Jan 2017
    74
    best regards,
    Greg
    I was thinking the same thing. Why would Citroen put shift marks for the run-in period on the speedometer but not after the run-in period.
    I noticed I can push the engine a bit higher than the rev marks but I have not pushed it very far. On my Trabant being a 2 stroker, it's impossibly unless I downshift. On that car, the engine simply stalls out at the shift marks. Well it doesn't actually have any on the speedometer, just based on the owner's manual. Must be a characteristic of the 2 stroke engine.
    I once pushed my Subaru past it's limit while passing a slow moving car on 2 lane road illegally (dual yellow lines). The rev limiter kicked in!
    Jun 2015
    Athens
    34
    Here is my dash with leds.
    https://www.youtube.com/watch?v=tEXmbVqqWTc
    From 0:35'
    Feb 2012
    Ireland
    15
    What bulbs did you use Pierre ? They look great !
    Jun 2015
    Athens
    34
    Quote Originally Posted by darrenhendley View Post
    Make sure what type of bulbs your dash is using. There are bayonet and the ones you may see attached that I bought for myself.
    In the video description you can see the email of Gil that will help you choosing the right ones for you.
    Attached Thumbnails Attached Thumbnails Speedometer with LED bulb-unnamed.jpg
    Newcastle
    2,623
    Hi I thought that those numbers would be in MPH
    Jaahn
    Quote Originally Posted by turbofiat124 View Post
    Aug 2014
    Auckland, NZ
    162
    Brilliant job with the VHT Wrinkle Paint. I just couldn't get that consistency in my tests so I have a test in with the powdercoater of a wrinkle powder from 'Murica
    Bikes -
    Jun 2015
    Athens
    34
    Thanks!
    Check the my dash resto thread. You will find useful tips in case you will try again with VHT Wrinkle Paint.
    http://www.aussiefrogs.com/forum/citro%EBn-forum/123261-citroen-ds-21-dash-resto.html#post1461059
