C5 '06 Stop Brake System Fault
Like Tree2Likes
  • 1 Post By jaahn
  • 1 Post By Balki
Thread: C5 '06 Stop Brake System Fault
    Jan 2017
    Launceston
    4
    Default C5 '06 Stop Brake System Fault
    Hi all. My first post. I have recently purchased the wagon and working towards getting it roadworthy.
    The only real problem is the brake system fault that shows the STOP plus red brake symbols. Error codes C1383 brake fluid switch open circuit .. and C 1389 brake fluid level too low .. .there does not seem to be any brake performance problem. New pads and full fluids. Fluid level sensor has 48 oh resistance and 330mv across plug when dummy resistor sensor fitted, so that appears to be working. Should I current check?
    Are there any other sensors or connection s that should be checked?
    Mobile auto electric is coming to help soon.
    The service interval display also says 4C3 Brake fluid level error detected. Consistent at least. Any further ideas???
    Thanks.
    Sent from my HTC_0P6B using aussiefrogs mobile app
    Newcastle
    2,623
    Hi My mate had that problem with a Peugeot he purchased of about that year. Had to do other things too but at the end that brake fault remained. He ran around with a resistor in the circuit for a while to put the light out till it was sorted. I forget what value it was.
    He put another used resevoir with sensor and that fixed it. We tested the sensor first and it seemed Ok and was just two pins in the fluid but the computer did not like it?? My guess was that some combination of different fluids had left a coating on them ??
    Jaahn
    C5Danger likes this.
    Jan 2017
    Launceston
    4
    Thanks Jason, Sounds like a clue!
    Jan 2017
    Launceston
    4
    My instrument tech bro checked out the typical brake fluid sensors. They read 2.5ohms at low level and 2000 ohms when full. I fitted a 2k Oh resistor in to fluid reservoir plug and the STOP goes away. I can now replace the reservoir or sensor and it will make it through road worthy check. Thanks Jaahn for your help. 😄 John.
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    625
    i have a fluid level sensor here out of a 2004 c5, might be the same if you want to try it, im in launceston friday night if that helps
    jaahn likes this.
    2016 Cactus
    2003 Range rover l322
    1974 D special
    1971 D special
    1992 CX TGE Safari
    1961 ID19
    1972 DS21 Safari
    1965 Renault R4
    1923 Citroen B2
    1927 B14
    Massey ferguson 550
    Jan 2017
    Launceston
    4
    Quote Originally Posted by Balki View Post
    Hi Balki, that sounds like just the thing. I'm happy to meet up. John
