DS Triax boots and strapping
Results 1 to 10 of 10
    Feb 2012
    Ongar / England
    832
    Default DS Triax boots and strapping
    Hello, anyone tried the CV boot straps that use a pair of pliers to tighten?
    Like this
    http://www.ebay.co.uk/itm/C-V-Univer...sAAOSw-itXtIKQ
    To improve access, I was thinking of this
    Lisle Corporation 30600 CV Boot Clamp Pliers | eBay
    I hadn't invested in Ligarex, instead I'd bought a Sealey copy (mistake). It uses a tool like a pair of scissors with three handles, damn fiddly and not enough space. I used about 20 feet of strapping before getting them tight enough and strung together quite a few swear words in the process.
    Any views?
    Peter
    Apr 2016
    Bedford, UK
    705
    With the cost of the special pliers, this seems an expensive way to go? At least with the Ligarex kit you can use the strapping on other jobs on the car.
    Feb 2012
    Ongar / England
    832
    The pliers work with any 'eared' clip and the banding is available in smaller sizes. The pliers are available in the UK for about £40 all in. A Ligarex kit is £100 odd these days.
    I'll measure around the Triax joint tomorrow, maybe too big anyway
    Apr 2014
    Phoenix, Arizona USA
    674
    I just use a really large jubilee clamp.
    John T.
    8,184
    Quote Originally Posted by badabec View Post
    Pinza fascette acciaio a nastro, ligarex e Panduit | eBay
    Ligarex buckle for 5mm strapping - Pack of 10
    Ligarex strapping stainless steel 50 metre roll x 5mm wide
    You know you want to. . .
    08 C5 X7 HDi very Noir
    Fellow Frogger! marc61's Avatar
    Jul 2013
    Stamford, UK
    331
    Large jubilee clip works well, is easy to do up and undo, and can be re used. Its a lot easier to fit than Ligarex in this application.
    Marc
    Cheers, Marc.
    1987 CX GTi T2 Maikonics
    1972 SM 2.7 carb
    1972 DS21 EFI
    9,771
    You really want to use Ligarex on the small end of the rear suspension boot as it turns back on itself. Elsewhere it's not as important.
    Apr 2014
    674
    For what its' worth, according to my personal notes, the Triaxe boot requires a 5-1/4 inch diameter clamp. I use McMaster 5574K27 Smooth-band Worm-drive Hose Clamp, 4-3/4" To 5-1/2. On the first installation, you have to form the clamp around the triangle a bit. Orient the drive as close to the middle of the flat as possible.
    John T.
    Apr 2016
    Bedford, UK
    705
    Bloody hell! Just looked at the price of Ligarex these days! You can pay significantly more than £100. I think I paid about £35 for the full kit (pliers, buckle and dispenser) from Pleiades back in the day.
    Feb 2012
    Ongar / England
    832
    Hello, I've taken all your advice, have stopped over thinking the problem and have bought some giant Jubilee clips. I've gone for the quick release versions like this
    Browse our Quick Release Straps range
    I know I want to get a Ligarex kit, it is about number 42 in my top ten list of things to buy.
