2CV on wharf
Results 1 to 7 of 7
Thread: 2CV on wharf
    Albany WA
    249
    Default 2CV on wharf
    Saw this 2CV on Tauranga warf in New Zealand. Ready to be transported to the lucky new owner.
    If he (or she) is interested in some photo's let me know.
    Member netmatelot's Avatar
    Jun 2012
    Lincoln, UK
    37
    A 1986 Brit registered 2CV in New Zealand, nice!
    Albany WA
    249
    Quote Originally Posted by netmatelot View Post
    Won't be Brit registered for long I think.
    Feb 2016
    North Yorkshire
    104
    Hope it had a good sort out before heading off on its holidays; the MOT test history during the last 5 years/8,000 miles has been rather chequered.
    2012 was a particularly hard time, the MOT tester may have had to sharpen his pencil at the halfway mark...
    • 21 November 2012
    • Test Result Fail
    • Odometer reading 54,121 miles
    • MOT test number 8088 8672 2311
    • Reason(s) for failure
      Front Body has a sharp edge caused by corrosion (6.1.C.1)
      Offside Front position lamp(s) not working (1.1.A.3b)
      Nearside Headlamp aim too far to the left (1.8)
      Offside Headlamp aim too low (1.8)
      Offside Headlamp aim beam image obviously incorrect (1.8.A.1b)
      Exhaust emissions hydrocarbon content excessive (7.3.B.1b)
      Nearside Outer Front constant velocity joint gaiter deteriorated to the extent that it no longer prevents the ingress of dirt etc (2.5.C.1a)
      Offside Outer Front constant velocity joint gaiter deteriorated to the extent that it no longer prevents the ingress of dirt etc (2.5.C.1a)
      Nearside Front Front wheel bearing rough when rotated (2.5.A.2)
      Offside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
      Nearside Front Tyre has a cut in excess of the requirements deep enough to reach the ply or cords (4.1.D.1a)
      Offside Front Tyre has a cut in excess of the requirements deep enough to reach the ply or cords (4.1.D.1a)
      Nearside Rear Tyre has a cut in excess of the requirements deep enough to reach the ply or cords (4.1.D.1a)
      Offside Rear Tyre has a cut in excess of the requirements deep enough to reach the ply or cords (4.1.D.1a)
    • Advisory notice item(s)
      Body has slight corrosion (6.1.B.2)
      Exhaust has a minor leak of exhaust gases (7.1.2)
      Brake pipe slightly corroded (3.6.B.2c)
      Nearside Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
      Offside Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
      Under-trays fitted obscuring some underside components
      Oil leak
    Albany WA
    249
    I don't think the Kiwi testers are as tough as this guy. He obviously doesn't like French cars.
    Feb 2011
    brisbane Au
    927
    A common enough scenario. Pick as many faults as you can think of and then put in a ridiculously low purchase offer. Works well here in Qld, why not elsewhere.
    Jun 2012
    Lincoln, UK
    37
    Quote Originally Posted by Winkbul45 View Post
    Unfortunately this is how the modern MOT works in the U.K.! It can sometimes be hard to get an older car through, for example my DS failed a few years ago because it had a tiny drip of LHM underneath somewhereÖit's an old CitroŽn, what do they expect??
