citroen C5 with AL4 no reverse
    May 2012
    burnie tasmania
    14
    Default citroen C5 with AL4 no reverse
    the car drive forward appears to change and drive ok but on reverse at all any ideas what is wrong
    Aug 2016
    Sunshine Coast, QLD
    889
    Did you remove the valve block at any stage? I would say the manual piston has been installed backwards, this is the piston that should be locked into the quadrant.
    Does it drive forward in all gears when in manual mode?
    Sent from my GT-I9195T using aussiefrogs mobile app
    Feb 2011
    brisbane Au
    927
    Quote Originally Posted by andy bram View Post
    Assuming someone hasn't been trying out their Christmas prezzie spanner set. If you have first and third gear, rule out a clutch problem and suspect a broken brake band or the number 5 control solenoid. Or it's electrical connectors of course.
    Oct 2013
    Epping
    108
    hi there, it can be checked for a broken band without removing the transmission.
