DS Ownership journey begins - Page 5
Page 5 of 5 First 12345
Results 101 to 107 of 107
Like Tree26Likes
Thread: DS Ownership journey begins
  1. #101
    8,049
    Icon3
    Quote Originally Posted by Arekisir View Post
    Hi Chris thanks for the offer of the tap - a rare tool. I remember reading about this modification but did not have the detail so not sure what i am looking for - attached is my weber fuel inlet hose / brass connection. Since I have a non standard electric fuel pump I assume I will be changing the hose from the pump to the carb. It is listed as 5/8".
    Is this applicable to my setup?
    Alex
    Attachment 95420
    Hi Alex,
    I can't tell from your pic but you may already have a threaded brass connection at the carby?
    Should look like this or similar
    5/8" sounds right for the fuel hose, also as you are using an aftermarket electric fuel pump consider a tachometric relay for safety. . . or you might be out of the frying pan and into
    Tachometric Relay for Electric Fuel Pump - - :: Just Kampers Australia
    08 C5 X7 HDi very Noir
  2. #102
    Los Angeles, CA USA
    1,960
    The cylinder head should be retorqued and the valves adjusted after you have run the engine 750-1000km. 500-600 miles.
    Sent from my SM-G930V using aussiefrogs mobile app
  3. #103
    May 2014
    103
    Been too long since an update.
    Progress has been made on rust areas. Overall not a lot of rust but one area I did find was the lower attachment point for one of the front bumper rubbers.
    I made up this repair pannel from some scrap gal sheet - I think any D cant have too much sacrificial zinc.
    Borrowed a mates mig for the welding. Took a bit of time to stretch the metal to the little bit of compound shape but came up ok - for an amateur.
    The old parts and the made up pannel and captive nut
    The repair in place tacked in.
    forumnoreason, Budge and kenlin like this.
  4. #104
    Apr 2016
    Bedford, UK
    556
    Nice work. Mental note to self: must learn to weld!
    1968 DS21bvh Pallas in Gris Palladium
    Restoration blog: https://ds-restoration.blogspot.co.uk
  5. #105
    16,090
    The hardest bit I've found is making a good enough patch panel to fit..... That is really well done
  6. #106
    Fellow Frogger! caparobertsan's Avatar
    May 2011
    SOUTH MORANG
    792
    good job!
    1961 Citroen ID19(2010~), Holden Frontera(R.I.P 2002-2014), Honda Accord EURO(2006~)
  7. #107
    May 2014
    103
    I have read countless warnings regarding the front wheel bearing seals not being up to much as far as keeping out contamination.
    They are sealed for life and the proper rebuild looked pretty daunting.
    The guys in the Netherlands put up a great YouTube video about adding in a grease nipple to the front hub to allow greasing the front bearings.
    I added this grease nipple and initially used it to flush out the bearing I figured if the seals can't keep rubbish out they can't keep rubbish in.
    I setup a fuel pump, multiple inline fuel filters some hose and a bucket. It's best to do this on a rotating bearing so second gear at idle was my carefully calculated rotation speed.... I used kerosene despite not enjoying the odour much.
    A lot of rubbish came out. The cheap ebay fuel filters don't filter well despite using 4 in series. I changed the kero to finish it off.
    Adding the grease back in I put in slow while the bearing spinning easy to blow any seals with a grease gun.
    Hope this makes some sense, not a rebuild in any way but a good way to achieve non invasive preventative maintenance.
    Alex
