Hoses compatible with LHM.
Results 1 to 15 of 15
Like Tree8Likes
  • 1 Post By DoubleChevron
  • 1 Post By citroenthusiast
  • 1 Post By agd123
  • 1 Post By Ken W
  • 1 Post By forumnoreason
  • 1 Post By moulton2speed
  • 2 Post By Le Parisian
Thread: Hoses compatible with LHM.
    3,580
    Default Hoses compatible with LHM.
    Not knowing yet where the leak(s) are, but will have to renew a few no doubt. My question is, are genuine ones available? If not and i go to places like Autocheap or Repco, what tro look for? Advice appreciated, especially from Parisian!
    16,415
    Any nitrile hose from your local pirtek type place should work. Finding hose that isn't re-enforced (so flexible) is the fun bit. You will also find Citroen are bastards for putting a different internal diameter into each end of the one bit of hose.
    You will no doubt find the leaks are the rear boots ... I need to replace all 4 on the ID's here I'm pretty sure. Oneday ....... When some money grows on the money tree again.
    Bad Bertie likes this.
    Apr 2014
    Phoenix, Arizona USA
    674
    Anything that is good for fuel will work with LHM, so autocheap will have most of what you need. 1/4, 5/16 and 3/8 works for most of the return lines. The pump suction line is about 1/2 so not as easy to find at autocheap. Industrial suppliers will have the 4mm O.D. nylon (pee line). Use 1/8 unreinforced buna rubber tubing (also from industrial supplier) to make the connections for the 4mm stuff.
    John T.
    Dec 2010
    canberra
    169
    Enzed is useful too, I used reinforced fuel hose with little problem. However make sure you use good hose clamps at each end. Also there are brass joiners available for those hoses with different sizes at each end, solves the hose with different sized ends problem well. Of course they have elbows, tees, etc so you can make up your own harness (yours would have to be more logical than theirs!).
    Hope this is useful.
    Regards
    agd123
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,925
    Mackay EFV hose is good and can be purchased online in 3 different sizes.
    Cheers Ken
    Ici.
    2,560
    have a look at the return hose from the regulator as that one is regularly perishable item! Usually needs replacing if not regularly used or unmaintained for long periods.
    Dec 2010
    Wagga Wagga
    346
    I have used fuel hose for return lines. For the pump suction hose, a hose used for oil cooled turbo chargers works well. I got mine from Denco Diesel.
    Fellow Frogger! Le Parisian's Avatar
    Guildford West
    359
    Quote Originally Posted by Bad Bertie View Post
    I use Fuel hoses as a substitute for LHM you can buy them from super cheap. Measure the diameter of your hoses before you get there as they come in different sizes better still take a sample with you, having said that I also bought a selection of LHM hoses from Citroservices . Check all your suspension rubber boots front and back these are probably your culprit. If you can’t see any leak I would assume it’s not from the high pressure circuit but more likely from your return lines. Have a good look all over the car I’m sure the section which is leaking will show wet patches dry the area and observe.
    Repor tback
    Bounge and Bad Bertie like this.
    3,580
    no, the leak is in the front somewhere, near motor .
    3,580
    Will do!
    3,580
    Quote Originally Posted by Le Parisian View Post
    Repor tback
    I will report back as soon as i found the leak. last worked on the car two days ago, and made good progress with the cleaning!
    3,580
    Thank you all guys with the suggestions. Merry Christmas to you all.
    16,415
    The hoses will be split where the push over the barbs. shine a torch down the passenger side of the motor and have a look at the return line junctions. Don't forget the power steering return line. It could also be where the hoses attach to the bottom of the reseviour. I would expect that to drip further forward though. Leaking front suspension boots can run down the high pressure lines and drop from underneath in my experience too.
    8,184
    Icon3
    Merry Christmas to you Bertie
    Has the level dropped noticeably since you topped it up? As a guide 40mm equates to about a litre of LHM on the sight tube.
    All you can do is clean the suspect areas and inspect for leaks. Rubber returns lines under the tank and in fact the metal tubes they attach to on the tank or pin holes in the bottom of the tank. Given the amount of LHM lost it shouldn't be too tricky to pinpoint the leak(s). Get the car on axle stands and remove the undertray, a good cleanup and have a good look with a torch.
    08 C5 X7 HDi very Noir
    Apr 2014
    674
    Also, a very common leak source is the plastic 4-way Tee attached to the LH bulkhead somewhat underneath the LHM reservoir.... These get brittle with age, then one nipple breaks off and everything in the return lines that should go back to the LHM reservoir ends up on the pavement
    John T.
