DS second or first nose bonnet?
Results 1 to 19 of 19
Like Tree3Likes
  • 1 Post By daffyduck
  • 1 Post By forumnoreason
  • 1 Post By Budge
Thread: DS second or first nose bonnet?
    Sep 2014
    adelaide hills
    21
    Default DS second or first nose bonnet?
    Hi all
    Can anyone clarify whether the bonnet is the same, between the first and second nose, I can see the differences between the front guards undertray and bumper.
    thanks
    Gary
    Melbourne, Victoria.
    1,389
    Hi Gary, I don't think the bonnets changed. The guards and headlights did, but I'm pretty sure the bonnets were the same.
    8,184
    Quote Originally Posted by George 1/8th View Post
    There are differences to the bonnet, it's been too long but one is the fold at the windscreen to accommodate the change of wipers from clapping hands style to parallel style. Others will step in here but I think the first nose was slightly more blunt at the front peak?
    08 C5 X7 HDi very Noir
    Los Angeles, CA USA
    1,955
    There are 3 bonnets. 1st and 2nd are nearly indistinguishable at a glance.
    Do the dance. Do the Daffyduck dance using the Aussiefrogs app. Be real happy if you can.
    UFO likes this.
    Apr 2016
    Bedford, UK
    705
    The change in nose style happened for the 63 model year, but clap-hand wipers continued to be used until the 65 model year. So it's possible that there were four bonnets: original, switch to second nose, switch from clap-hand wipers, switch to last nose.
    9,769
    How many does the parts list show?
    Early cars had the stay on the left, so there may be some minor differences there too.
    Trainspotter alert! There'd be a spot for you guys on ABC TV's 'Hard Quiz'.
    8,184
    Icon3
    Manual 466 shows 2 part numbers, DS 852 - 2b and 2c with changes from September '62. From what I can see most of the changes relate to hinges/bonnet catches and release.
    I have a vague recollection of Arthur Lewis (Brisbane Citroen guru in the '70s) converting a 1st nose bonnet to 2nd so the basic shape might be the same for both.
    Attached Thumbnails Attached Thumbnails DS second or first nose bonnet?-bonets-1st-2nd.jpg
    Ici.
    2,560
    Yes someone on here should go on as a D specialist, its amusing enough but add a D tragic and it would be the best entertainment yet.
    Come on! That trophy bucket would make a good LHM catcher!
    GreenBlood likes this.
    Apr 2016
    Bedford, UK
    705
    I think I'm suffering from PME...... Parts Manual Envy.
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,344
    I have at least 20 different D parts catalogues (that are called catalogues, not manuals; the repair manuals are called manuals). I looked up bonnets in some of them yesterday morning but was in too much of a hurry to post my findings. Now I am half a world away, I have to rely on memory.
    DS 852-2 is the earlier model with left hand stay referred to above. I see no reference to a D 852-2, even in the 1956 catalogue. (Generally, the earliest parts have a D prefix and at the first change a DS prefix was used.)
    There was some variation in windscreen washer nozzle mountings, too. My 1959 bonnet has only a central nozzle.
    DX 852-2 is the later second nose bonnet for DS19A and DS21, with parallel wipers.
    Roger
    8,184
    Icon3
    No need for PME (or PCE)
    Roger and a few others have made most Manuals and Catalogues available as PDFs
    Red Fluid
    https://www.dropbox.com/sh/txhoyw2gqvc8lau/LnhQmqmhRh
    Green Fluid
    https://www.dropbox.com/sh/tv0b25gpmd5ux8e/e-HYMQrA3e
    Quote Originally Posted by Tony Jackson
    Note – where possible, please can you download the files you want to your computer, and keep a local copy, so you don’t have to download them again each time you want to look at them. You can tell if a file has been updated since you last downloaded it, by checking the “last modified” date.
    We are seeing very high usage on this server, which we think is partly due to people downloading the same file again each time they want to view it. This high usage is causing us problems, and we provide this service for free, so your help in reducing usage would be much appreciated!
    Sep 2014
    adelaide hills
    21
    Thanks for replies, Ive got I think is a early 62? bonnet which I may combine with second nose guards, undertray,bumper onto an donor "FRANKEN "D 3rd nose car,
    hope this does not offend!
    Gary
    Apr 2014
    Phoenix, Arizona USA
    674
    Does the donor car have its original wings? Beware, third nose wings will not work with a 1st or 2nd nose bonnet. Third nose bonnets are considerably narrower than 1st or 2nd to make room for the quad headlights..
    John T.
    Apr 2016
    Bedford, UK
    705
    So you're basically trying to put an older style front (bonnet wings and bumper etc) onto a later style chassis - from the screen and doors back? Will that work? I think that the 'tusks' of an early car are different (and possibly shorter) than the 'tusks' of a later car? I had heard this - but you really need to hear from someone that has already tried this.
    Warrnambool
    2,344
    I know people who have done it and I don't think they had to modify the front horns.
    Roger
    Apr 2016
    Bedford, UK
    705
    Happy to be corrected on this point Roger. I have a 68 and occasionally (3 or 4 times a day) fantasise about putting a 67 frog eye nose on my car .....
    Warrnambool
    2,344
    Sorry Budge, I cannot advise you on the details because I have not gone into it in any detail.
    Maybe get some crappy front wings and have a play. They would be the critical panels because they mount to the frame and the bonnet mounts to them.
    Roger
    Jun 2002
    Newcastle, NSW
    74
    Hi Gary,
    Roger is right, as he always is . I've seen a couple that have been converted. The chassis legs, called 'front extensions', in the post 67 cars are longer but shouldn't need shortening. The pre 67 bumper will bolt on a little further back than the post 67 bumper.
    You have almost all the parts to do the change, but it's Citroen so it's a little more complicated. The front cross-member that holds the air-horns may be a problem. They were very different after the 67 change. At first the new shape was bolted on but sometime later they were welded in making changing a little more challenging.
    Peter
    1000+ Posts dogboy's Avatar
    melbourne,victoria,australia
    1,332
    my latest Citroen is a 1964 Safari that was converted to LHM and had late front wings,bonnet,DS23 engine with 5 speed and a 3 dial dash,
    Rev. Dogboy
    1969 DS21 Pallas BVH with leather
    1970 Renault 16TS
    1967 Honda S800 cabrio
    Citroen 1970 DS21 Cabrio replica
    Citroen 1966 ID Safari (with 23 running gear)
    Citroen 1975 DS23 Safari
    1975 VW Kombi poptop
    1987 2CV
    Porsche Boxster S manual
    1988 Vespa PX200E
